1. MattyDillon77's Avatar
    5 or 6 weeks ago I upgraded from iphone 4 to Samsung Galaxy s4. Within 2 weeks I was 1gig over my 2.5gig data limit. I waited 1 and a half weeks for it to reset and after 5 days im already at 1gig. My job is to drive from job site to job site and whilst my coworker does his part of the job I sit in the car using my phone. Today I left a site with 409mb used by android os and got to the next with 579mb(roughly from memory) I have turned off auto sync, I dont have email account attatched, Facebook etc has been put on wifi obly background use etc. What is causing my problem. 1g in 5 days is bad and without data for Facebook or instagram my job is virtually unbareable. I cant go over again it cost me a fortune please help!!!
    Attached Thumbnails Series data issue please help!-screenshot_2013-07-17-13-23-34.jpg
    07-16-2013 10:37 PM
  2. mhinc's Avatar
    My guess based on your screen shot is the Android OS 579mb is from doing a Major Update when you first turned on the phone. And it appears you did so over your Data and not Wifi.
    The second part is Instagram, when you installed it you didn't read and it uploaded a **** load of photos to it's servers because you didn't uncheck the option to do so after install.
    My guess that **** load of photos was on a Micro SD card you put in the phone when you got it that was filled with photos from another device.
    If the above is the case, then you shouldn't have to worry about any more surges in your data, make sure under ABOUT DEVICE and then SOFTWARE UPDATES you choose them to happen over WIFI ONLY going forward. And as for the Instgram issue. Same thing happens with programs like DropBox, it will upload your ENTIRE Micro SD card full of pics unless you tell it not to.
    Does the above make sense as to the cause of your issue?
    07-17-2013 07:11 AM
  3. CrossClown's Avatar
    Go to your data usage then click on, let's say, Android OS or Instagram, then scroll down and check if it's the background data or the foreground data. If it's the background data you can either disable background data as a whole for your phone or selective disable data for each app that's running. If you disable background data as a whole for your phone, you won't be able to auto-retrieve MMS and Google Play will bug your for not having background data on.
    07-17-2013 07:18 AM
  4. MattyDillon77's Avatar
    It is 100% background data. How do I turn background data usage off for android os? There isn't a box to check under the background/foreground pie chart on usual apps.
    07-18-2013 03:16 PM
  5. MattyDillon77's Avatar
    No I don't have a micro sd card at all. My problem isn't instagram of Facebook because I use these ALOT so the large data use for them is understandable. It's just the massive amounts of background data use by android os. It can't be an update because it jumps sometimes 100mb in one day. Everyday apart from weekends because im on wifi alot.
    07-18-2013 03:19 PM
  6. paintdrinkingpete's Avatar
    Could it be YouTube? I see that YouTube is further down on the list, and I've read before that the app itself only logs data for the browsing/searching features, but the actual video downloads are registered as "Android OS"....and high def videos can be VERY large. If you watch even a few high def YouTube vids a day, that would definitely account for this.
    EDIT: If you suspect it may be this, you can check the settings in the YouTube app and make sure high def is off by default and disable pre-loading as well.
    EDIT2: Even if not in high def, lower def vids will eat data as well, though not as fast.
    07-18-2013 03:32 PM
  7. Amy Schwarz's Avatar
    I checked my usage and my "Android OS" is eating tons of data too. I'm on wifi 98% of time since I'm a SAHM so it only used 100 Meg's of mobile data but I checked my wifi data and it used 1.49 gigs in the last month so if I wasn't on wifi I would of went over my data too! I wonder wtf this is?
    07-18-2013 09:49 PM
  8. Amy Schwarz's Avatar
    Ahh this would make sense for me! I watch a decent amount of you tube and mine only shows 40 Meg's of data used for that.
    07-18-2013 09:53 PM
  1. How can I Transfer apps and all data from old Nexus 7 to a new one??
    By Webster Phreaky in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-02-2015, 01:58 AM
  2. Need help with weird battery level readings
    By Leonard Shatner in forum Motorola Droid X2
    Last Post: 08-28-2013, 05:02 AM
  3. I want to buy the phone, not the carrier please
    By Steve Hartzog in forum Samsung Galaxy S4
    Last Post: 07-24-2013, 04:54 PM
  4. rooting and update help for s4
    By iby123 in forum Samsung Galaxy S4
    Last Post: 07-16-2013, 07:55 PM
  5. samsung s4 update help
    By iby123 in forum General Help and How To
    Last Post: 07-16-2013, 07:54 PM
