1. Man In Black 805's Avatar
    Hey guys, I'm new and this is my first post,
    I just received my Galaxy S4 (On Verizon's Network), previously had the Droid Charge (absolutely the worst phone ever invented, I went through 5 of them), anyways, something I've noticed with my S4 is that when I'm in the car and have the 1/8" stereo jack plugged into my car's receiver to listen to apps like Pandora, or others, I get an extremely loud static when I also have the charger plugged into it, though it stops when i remove the charger, I've tried various different chargers (O.E.M. Samsung / Verizon, ect.), but all had the same issue, has anybody heard of this yet?
    07-17-2013 04:11 AM
  2. snookasnoo's Avatar
    I have the same thing.
    07-17-2013 10:34 AM
  3. Ruhnie's Avatar
    It's a ground loop problem, I had the same thing. Go buy this and use it as your audio cable, fixed it for me:
    Amazon.com: Kensington Noise Reducing Car Audio AUX Cable for MP3 or SmartPhone, including iPhone 4S: MP3 Players & Accessories
    07-17-2013 11:28 AM
  4. dakhath's Avatar
    This is correct. I agree.
    It's not your phone, charger or the cable causing the problem.
    Cars have very "dirty" electrical wiring.
    I had one car that you could listen to the spark plugs firing if I plugged in my phone to the stereo and the charger at the same time.
    The cable Ruhine suggested should help reduce or eliminate the sound.
    It's the easiest solution to try first.
    07-17-2013 12:16 PM
  5. Man In Black 805's Avatar
    Interesting, I will try this solution, but I've used the same charger & audio cable for years with my previous crap phone and had no problems with the audio quality, that's why i thought it had to be the phone.
    07-18-2013 12:39 AM
  6. Ruhnie's Avatar
    The phone certainly plays a part in it, I had the same experience. My last phone was fine with a cheap cable in the same car. Soon as I got the S4...horrible, awful noises.
    07-19-2013 05:27 PM
  7. jeffreii's Avatar
    I used to have the same problem with my BlackBerry and S3...but now use Bluetooth only with my S4...but I bought one of these:
    Amazon.com: PAC Ground Loop Isolator for 3.5 MM Applications: Automotive
    It worked perfectly and fixed the problem. Cheaper than the Kensington linked above and the same high reviews.
    07-20-2013 11:21 AM
  8. iccard's Avatar
    Here is how I stopped the static... turn up the sound volume on the phone to at least 3/4 volume. Turn down the car volume. Static went away. I think the power draw of the car speakers exaggerated the static. With the car speakers drawing less power it works perfect.
    08-29-2013 06:51 PM
  9. Tito DeLatorre's Avatar
    Car speakers don't draw power, they are given it, learn basic car audio please.
    05-14-2014 03:21 PM
  10. Jorge Arce's Avatar
    Tito,
    Speakers do not produce power. Any speaker needs external power to work, and in cars, most speakers are passive, meaning they need an external source of power ie: a head unit and/or power amplifier. Even in the case of active speakers, they are only active because they have a built in amp that powers them without the need to draw power from the head unit, receiver or what have you... But you already know that, don't you?
    They do not draw voltage or amperage but do not produce or "give it" either, voltage nor amperage are not necessary to produce sound, only to power the source that produces the sound. They draw watts, which is the unit used to measure the output needed to excite the coil in the speaker which then transfers the sound to the membrane which will produce the specific frequency range it was design to produce, but again, they don't have the capability to produce or "give" any type of wattage or power on their own. So your comment is incorrect.
    That is as basic as it gets when it comes to car audio!
    05-19-2014 08:13 AM
  11. Bandit24's Avatar
    01-08-2017 01:16 PM
  12. Bandit24's Avatar
    Static reducer
    01-08-2017 01:17 PM
  1. Do you guys use iOS in addition to Android?
    By RavenSword in forum General News & Discussion
    Last Post: 10-27-2014, 12:56 AM
  2. Audio plays only right channel
    By Droid Brick in forum Verizon Galaxy S III
    Last Post: 07-16-2013, 10:22 PM
  3. iOS-like badge using Missed It!
    By DrZach21 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-16-2013, 06:55 PM
  4. Lost some contacts when setting up new phone
    By windycityrider in forum Verizon Samsung Galaxy S4
    Last Post: 07-16-2013, 06:42 PM
  5. Question on rooting to GE and beats audio and uodates
    By TheyStoleMyName in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-16-2013, 05:09 PM
