Ty Knotts
I have bought a new camera module. and it still does not work....I have given up. I have a smart phone with no camera. This blows!!!
Simulatie problem andere if I Dow *#34971539# I see a problem white the Rear main camera FW fer is difrend wat to Dow ??I had the same issue after migrated to 4.4.2... After 2 months of research i could finally found a way to fix it !!
- enter the code *#34971539# in your phone to enter in the camera settings page
- click on "Phone to CAM FW write (Rear)" (you may be asked to update the firmware". Click yes
- reboot
it looks that for some reasons the firmware was not updated correctly ...
Hope it helps !!
- reboot
Hope it helps !!
