Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Almeuit
    Seth_Overbury's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy S4--SMS Notifications Don't Work--Help!
    I have a Verizon S4--actually my second one due to a charger issue--and I have had this problem with both. The notifications don't sound when I get a text message. I have checked all settings (I am not new to Android or Samsung phones). If I restart my phone, the notifications work again--vibrate & sound. But after a day or two, the sounds stop playing again--only the vibrate works when I get a text message.
    I am using a ring scheduler to silence my phone during work hours--I have tried two different ring scheduler apps with the same problem. For the first day or two after a reboot with the scheduler turned on, it works fine. But then stops working. All other notification sounds work fine with the scheduler and don't have this problem. However, if I uninstall these apps it doesn't have this issue. It leads me to believe that the ring schedulers are causing this issue, but they are so handy! Does anyone use one and not have this problem? If so, which one and I will try that one?
    I have also tried a fast reboot app but it doesn't work. I have to do a full restart to make the sounds start working again.
    Any ideas?? Please help!
    Thanks!
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S4--SMS Notifications Don't Work--Help!
    Has anyone else experienced this problem at all?
  3. #3
    Almeuit's Avatar
    Posts
    Global Posts
    23,292 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    It seriously sounds like your ring schedule apps. I'd email the developers and report the bug as that's what it seems to be.. Especially once you uninstall those apps it doesn't happen anymore. It seems the app isn't un-silencing your phone like it should.
    Sent from my T-Mobile HTC One using AC Forums.
    Nerelda likes this.
  4. #4
    shkim698's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can always use the pre-installed setting 'blocking mode' & set the time rather than using a third party applications.
  5. #5
    msugrad598's Avatar
    Posts
    Global Posts
    76 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem using a ring scheduler. Once I uninstalled the ring scheduler the notifications worked again.
    Posted via Android Central App on my Samsung Galaxy S4
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by shkim698 View Post
    Unfortunately, I have the Verizon version. From what I understand, they have blocked this feature on their version of the S4. Infuriating!
  7. #7
    shkim698's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Seth_Overbury View Post
    didn't know there is such a massive difference between all these S4 versions
  8. #8
    Not Quite Right's Avatar
    Posts
    Global Posts
    1,411 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's funny they "blocked" blocking mode LOL. If that's true (which makes no sense) it's totally time to switch carriers ...
  9. #9
    paintdrinkingpete's Avatar
    Posts
    Global Posts
    4,297 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    TNTC
    Quote Originally Posted by Not Quite Right View Post
    For reasons that no one can seem to fathom or explain, Verizon has been removing Blocking Mode since the GS3...Not sure why. I don't know if this alone would cause me to switch carriers (though Verizon does enough other stuff you could pile on to this), but it is annoying.
  10. #10
    Posts
    Global Posts
    1,411 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't like bloatware, but I understand it. Removing useful features just for the hell of it is unexceptable.
  11. #11
    fantom305's Avatar
    Posts
    Global Posts
    574 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just one question: You don't have the capability of putting the phone on vibration or silence during working hours ? without needing a third party app ?
  12. Thread Author  Thread Author    #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fantom305 View Post
    That is correct. That feature/option doesn't show up on the Verizon S4 at all. It is crazy stupid.
    Unfortunately, where I live Verizon is the fastest and most reliable--there really is no other option.
  13. #13
    dakhath's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So your telling me that this button is missing on the Verizon variant of the S4?
    We really could use a list of all the variations between models. The more I read the more crippled the Verizon model becomes.
  14. #14
    robertdownie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can you tell me if the notification sounds work on the galaxy s4. I get no sound at all when I get an e-mail, but it sounds when I get a text. I think there is something wrong with the phone and I'm thinking about send it back as I've only had ot 8 days. I also think its very slow loading pages on the Internet .
  15. Thread Author  Thread Author    #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by robertdownie View Post
    This is the only problem I have. And it seems to be caused by the 3rd party ring schedulers that I have been using. All other notifications work for me just fine. Also, mine is pretty quick--doesn't lag at all on the internet (4g or wifi).
  16. Thread Author  Thread Author    #16
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dakhath View Post
    That is correct. This option is missing completely on the Verizon S4. I would love to see a complete list of variations.
  1. Sending empty sms
    By Niloofar6 in forum Google Nexus 4
    Last Post: 06-05-2016, 03:20 AM
  2. $15 amazon gift code to whoever can help me root the ematic genesis prime
    By TapZoo Cheats in forum General Help and How To
    Last Post: 08-14-2013, 08:15 AM
  3. Turning off Push Notifications
    By Scott72 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 08-11-2013, 01:01 AM
  4. Need help choosing a Rom
    By Chandnit in forum Samsung Galaxy S3 I9300
    Last Post: 07-24-2013, 09:55 AM
  5. No App Push Notifications
    By Brian37776 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-23-2013, 09:02 AM
