Since I got my phone, I've had battery life all over the board...anywhere from 30 hours of battery life down to 7. I've blamed Yahoo Messenger, GPS, Air View, several other things. So I've been taking some time trying to figure it all out. And here is where I'm at so far. Yesterday I made several adjustments, particularly to air view and gesture settings (mostly turning on some things). Today, my battery barely lasted 6 hours. The significant thing I noticed is every time I pulled the phone out of my belt pouch, the phone was hot, like it had been on. And screen drain on the battery was showing around 71%. I recharged again, left the phone sitting and found that most of the heat was gone, except just near the top around the camera lens. And I still saw heavy battery drain.
I turned off air view, topped off the phone again and let it roll. Now after a few hours of use, the battery power only dropped about 5%. In fairness I also had logged out Yahoo IM. But the phone did not overheat in the pouch.
So now my theory is, the Airview feature is causing the phone to activate inside the pouch. If this proves out, does this mean a defect? Or an incorrect setting? Shouldn't the proximity monitor be protecting that from happening?
Now my second thought is, if this is to be expected, maybe I need to look at a way to turn off airview while the phone is in the pouch. I'm thinking NFC. Would putting an NFC inside the pouch that cuases this to happen work? Is there a danger in leaving the phone in close proximity to NFC? I believe NFC is meant for touch and remove, so not sure putting one inside the pouch is a good idea. And would there be a way to reverse the action when the phone is REMOVED from the pouch?
I just grabbed the BetterBatteryStats app in hopes of trying to chase this down.
Any other thoughts?
Any other thoughts?
