Results 1 to 9 of 9
    420benz's Avatar
    Posts
    Global Posts
    356 Global Posts
    Default Phone won't turn on.
    All I get is the Verizon logo. The only way to turn it off is to remove the battery.
    Need help.
  2. #2
    Default Re: Phone won't turn on.
    Contact Verizon.
  3. #3
    Try booting into Recovery Mode and selecting "Wipe Cache Partition."
    How to enter Samsung Galaxy S4 Recovery Mode
    Alternatively, try booting into Safe Mode to see if some 3rd party app is causing the problems:
    Tutorial: boot S4 in safe mode
    420benz's Avatar
    Posts
    Global Posts
    356 Global Posts
    OK Now it is asking me how to complete action, go launcher ex,nova launcher,touch wiz easy home,and touch wiz home.
  5. #5
    What did you do to get to that screen?
    420benz's Avatar
    Posts
    Global Posts
    356 Global Posts
    Quote Originally Posted by B. Diddy View Post
    I did what you said. A screen with very small print came up,so I tried touching the print and nothing. So I rebooted the phone and I got this screen. Before I do something stupid,which one should I use?
    420benz's Avatar
    Posts
    Global Posts
    356 Global Posts
    Anyone.
  8. Thread Author  Thread Author    #8
    420benz's Avatar
    Posts
    Global Posts
    356 Global Posts
    Fixed. Thanks
  9. #9
    Sorry I didn't reply earlier--was away from the computer. Glad you fixed it--I assume this means it's booting up normally? What did you finally do, go to Recovery Mode or to Safe Mode? The reason why I was asking you what you did to get to the screen in question was because I suggested 2 different solutions, which yield different menus. The menu with the small type was probably the Recovery Menu, and to move around, you need to use the volume buttons, then use the power button to select.
  1. Phone Frozen after new update!!!
    By palanilopez12 in forum HTC One M7
    Last Post: 08-06-2013, 01:10 PM
  2. Ghost App showing installed on Google play store website
    By Vir Viga in forum General Help and How To
    Last Post: 08-04-2013, 07:19 PM
  3. Is there a way to update my phone in one shot?
    By msoprano13 in forum Sprint Galaxy S3
    Last Post: 08-04-2013, 04:53 PM
  4. Replies: 2
    Last Post: 08-04-2013, 03:59 PM
  5. Replies: 1
    Last Post: 08-04-2013, 03:55 PM
