1. Nestles03's Avatar
    Some more questions from an Android newbie!
    As suggested, I downloaded ES File Explorer and used it to create sub-folders for ringtones and such.
    I then changed the ringtone for one contact and somehow it's now the default ringtone (don't want it to be). So I went to Settings, My Device, Sound and Ringtones. Instead of seeing a list of ringtones, the phone now lists a bunch of folders under: /storage/emulated/0. Here are my questions:
    1. Where are the ringtones stored?
    2. How can I toggle/switch back to the original view (original ringtone list)?
    3. When I changed the ringtone for one contact, I did it by editing that contact's settings. Any idea what I did wrong that changed the default ringtone?
    Thanks in advance for your help again!
    - - - Updated - - -
    Forgot to mention this is on a Samsung Galaxy S4. (still learning the ropes!)
    08-05-2013 06:26 PM
  2. scorpiodsu's Avatar
    - - - Updated - - -
    Ringtones are in system/media/audio/ringtones
    You have to make sure you navigate to lowest parent folder to get to the system folder. Side note, I havent seen so much trouble related to ringtones lol. I thought they went out of style . J/k.
    08-05-2013 06:59 PM
  3. Nestles03's Avatar
    I tried to back out of the /storage/emulated/0 subfolder by tapping on the "up" arrow which takes me to "0" still in the sd card. How do I get back to the system folder?
    On your side note, glad I could provide LOLs!
    08-06-2013 05:56 PM
  4. boudicca00's Avatar
    - - - Updated - - -
    I'm having the same problem as you, especially #2. Blowing out the cache in general, rebooting, or deleting the custom ringtones I put on the external sd card, all aren't fixing it. My Samsung Note 3 stubbornly isn't letting me "see" (much less select), the location of the original files (/system/media/audio/ringtones). Using ES File Manager, I can see the files are there, but I think since it's a system folder, android doesn't really want me to go there, if it can help it.
    10-07-2013 11:26 PM
  5. Chethan Reddy's Avatar
    Settings > Application manager > ES File Explorer and clear default. Then go to change your tone/sound and it will ask which app you want to use. Sorry I didn't see this sooner!
    02-01-2014 10:59 PM
  1. Replies: 2
    Last Post: 11-06-2013, 08:05 AM
  2. Help with sound settings.
    By dotsgurl in forum Samsung Galaxy S4
    Last Post: 11-05-2013, 05:18 PM
  3. HELP!! Updated to 4.3 but tried to root from Nexus 4 Toolkit 4.2.2 and Now in Loop!!!
    By william hutson in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 08-06-2013, 09:08 PM
  4. Phone reboots nonstop and home screen is blank
    By cutesymin in forum Samsung Galaxy Note
    Last Post: 08-06-2013, 02:56 PM
  5. Both Galaxy Nexus do not charge when all 4 of our chargers are used in either phones.
    By rzessinger84 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-05-2013, 03:13 PM
