Results 1 to 6 of 6
    Default Is there anyway to use lockscreen widgets with a pin lock?
    Please help
  2. #2
    Default Re: Is there anyway to use lockscreen widgets with a pin lock?
    Nope. Only with the swipe lock.
  3. #3
    Quote Originally Posted by craigrn16 View Post
    Please help
    Yes there is, you have to encrypt your SD card and phone data - Go to settings >> More >> Security>> then choose to encrypt phone and then SD Card. After Swipe unlocking your phone it will ask you for your password to get past the encryption on the phone.
    hope this helps.
    thanks
    Quote Originally Posted by Teddy Jenkins View Post
    hope this helps.
    thanks
    Does it only work when you turn the phone on?
  5. #5
    Temporarily remove the PIN, add the shortcuts to the widgets. Once set, enable the PIN. You will not get it once the phone actually locks i.e. after 5 minutes, but you will see them when the screen times out i.e. 15 seconds.
  6. #6
    Well when I was playing around with those settings the other day if I turned the phone off and on you will need to put the code in to get past.
    I use widget locker and when I had the encryption in place widget locker still worked but after either unlocking it or launching something from the lock screen it would ask for the code.
    that's my experience anyway.
  1. Flashed to AOKP for my I545 (Verizon S4) - Very long reboot time
    By Kevin Owens4 in forum Verizon Samsung Galaxy S4
    Last Post: 01-18-2014, 05:01 AM
  2. Outlook: selecting which account to reply from
    By gavril in forum Android Apps
    Last Post: 08-14-2013, 01:51 AM
  3. Replies: 5
    Last Post: 08-08-2013, 05:04 PM
  4. Problem with sync..
    By Stewby85 in forum Sprint Galaxy S3
    Last Post: 08-06-2013, 09:16 AM
  5. Updating using an unlocked phone
    By hurricanekick360 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 08-05-2013, 10:16 PM
