Results 1 to 5 of 5
Like Tree4Likes
  • 1 Post By AndroidTuttons
  • 1 Post By mysticmeg
  • 1 Post By RH1Pearl
  • 1 Post By jeffreii
    Post Charging the Samsung S4 Battery
    Is it okay to charge the Samsung S4 Battery even when it's not yet fully drained? Say for example I only have about 40 percent and I need to go out. Will it affect battery life if I will plug it to a charger even when the battery percentage isn't below 20 percent yet?
  2. #2
    Default Re: Charging the Samsung S4 Battery
    I don't believe it will I do it all the time
    Thanked by:
    PrincessCar likes this.
  3. #3
    Quote Originally Posted by PrincessCar View Post
    Nope it shouldn't affect it at all.
    Sent from my GT-I9505 using Tapatalk 2
    Thanked by:
  4. #4
    RH1Pearl's Avatar
    Posts
    Global Posts
    546 Global Posts
    Some tips on extending your battery's life:
    1) Don't drain the battery all the way down before you charge it. I charge when my phone's at 10% with the exception of #2
    2) Drain the battery fully only once a month and charge.
    3) Never charge the battery while the phone is on
    4) Get an extra battery to enable the items above.
    5) Get the official Samsung charger as it's optimized to charge the battery faster (about 2 hours from 0 to full charge).
    For more details, go to the website Battery University
    Good luck and have fun with your S4
    Thanked by:
  5. #5
    jeffreii's Avatar
    CrackBerry Convert
    Posts
    Global Posts
    3,236 Global Posts
    ROM
    Goldeneye 4.0 + CWM OUDHS
    Quote Originally Posted by RH1Pearl View Post
    To OP, read this yourself ^
    I don't think discharging to 10% every time is healthy - it's almost a full discharge. Much better to charge far sooner, if possible.
    No need to drain it full once a month...it really does not need to be calibrated that often. If you use the phone normally this will probably happen once in awhile naturally, though, so don't even worry about forcing it to be fully discharged.
    You can charge the phone while it's on...just avoid doing it with the screen on for long periods of time as this will generate a lot of heat, which is the biggest enemy of battery life.
    To answer your first question again: yes, it's absolutely ok! You actually WANT to charge it more often. Your battery will last much longer with a ton of partial discharges rather than full discharges. Charge your phone whenever possible, as long as you won't be using it actively for most of that time!
    "Similar to a mechanical device that wears out faster with heavy use, so also does the depth of discharge (DoD) determine the cycle count. The shorter the discharge (low DoD), the longer the battery will last. If at all possible, avoid full discharges and charge the battery more often between uses. Partial discharge on Li-ion is fine; there is no memory and the battery does not need periodic full discharge cycles to prolong life, other than to calibrate the fuel gauge on a smart battery once in a while."
    And to end...don't worry that much about your battery. A high quality replacement battery from a top-rated vendor like Anker will cost you only $12...so don't stress!
    Thanked by:
  1. The New Nexus 7 hit the sweet spot! Then it bricked...
    By scottfish in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-26-2013, 09:09 PM
  2. Samsung galaxy note wont charge
    By johnmoore4 in forum AT&T Galaxy Note
    Last Post: 08-25-2013, 12:28 PM
  3. Replies: 23
    Last Post: 08-23-2013, 07:01 AM
  4. S4 Radio
    By ekmickens in forum Samsung Galaxy S4
    Last Post: 08-20-2013, 11:31 PM
  5. Stream recorder for Samsung Galaxy S4
    By Scotty Churilla in forum Samsung Galaxy S4
    Last Post: 08-20-2013, 10:45 PM
B
