1. Edible Walrus's Avatar
    Discovered this by accident today. How do I trigger it again? I triggered it twice by rapidly turning up the volume (strange thing is regardless of if I pressed OK or cancel it left the volume high). I can't seem to trigger it again thoug
    08-30-2013 09:45 AM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    I had a toast message that always came up when I got above a certain volume. But I had no input at all (GS3 though). Yours may have been a one time only warning. Still a legitimate disclaimer.
    08-30-2013 10:06 AM
  3. Darnell0216's Avatar
    Were you using headphones? This message pops up when something is plugged into the output jack and the volume goes up past a certain level. It will not pop up as long as the "current headphone session" persists. Once you unplug and plug back in, it will pop up again.
    08-30-2013 11:13 AM
  4. Edible Walrus's Avatar
    I tried plugging in the headphones again and doing it again, it wouldn't trigger. For some reason it triggered twice in a row when I first did it, but hasn't done since. I chose different options each time. Sometimes the music widget shows on lock screen and other times it doesn't. Phones not reading tags correctly, won't let me change album art and is duplicated albums. Every other device has had no issue with music once I've fixed the tags, but Android just won't listen
    08-30-2013 11:36 AM
  5. srkmagnus's Avatar
    I would agree with Golfdriver97 that it's likely a onetime warning. I can probably be triggered again by clearing the associated app data from the system settings menu. Which app controls this I don't know.
    Sent from my SPH-D710 using Tapatalk 2
    Golfdriver97 likes this.
    08-30-2013 01:26 PM
  6. Mitri360's Avatar
    It pops up when you have headphones in and the screen is off and it tries to go over the limit. It'll pop up. Only once though until you unplug the headphones.
    I hate that message
    08-30-2013 01:56 PM
  7. josearmz10789's Avatar
    On my S4 it does it when it reaches vol 9 go back down and wait a sec go up again and it should trigger it.
    Sent from my SPH-L720 using AC Forums mobile app
    08-30-2013 02:24 PM
  8. Darnell0216's Avatar
    It's an every time thing. It's so annoying that two different mods were made to completely disable the warning, one modifying files directly and the other used Xposed Framework. Turning on Adapt Sound for the stock music player will disable the warning there, but not in other apps. josearmz10789 probably has the right idea about lowering and raising the volume again.
    08-30-2013 02:42 PM
  1. Earpiece speaker volume low?
    By Bull2786 in forum Motorola Droid MAXX
    Last Post: 07-12-2014, 04:52 PM
  2. Replies: 5
    Last Post: 03-05-2014, 04:05 PM
  3. Volume mute issues
    By Fcubed74 in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-29-2013, 05:46 AM
