1. Colonels's Avatar
    So the latest build on stock Att gs4 has this charging profile:
    Using OEM wall charger and below 90%
    Screen off it charges 1.9amp
    Screen on it charges 1.2amp
    I have used the Motorola rapid car charger and it only gives .760-.800amp regardless of screen on or off, and this doesn't charge the phone while using GPS and full brightness
    Is there a car charger that will duplicate the OEM wall charger?
    09-08-2013 07:41 PM
  2. Darnell0216's Avatar
    Make sure whatever you get is a true 2 amp charger with a USB port and not an already attached cable. So far the OEM cable is the only cable that properly works with the S4, both in power supply and PC connectivity. Using 3rd party USB connects has so far been met with sub par results. Since you've figured that the phone loses ~.700 in charge strength while the screen is on, it's a safe bet that's where it all went when connected to the Moto charger and using GPS.
    09-08-2013 10:06 PM
  1. Wireless Chargeing
    By Malkozaine in forum Sprint Galaxy S III
    Last Post: 09-12-2013, 03:51 PM
  2. Graphics issue?
    By Samantha Hoy in forum Samsung Galaxy S3
    Last Post: 09-10-2013, 02:51 AM
  3. Some things about HTC One vs Galaxy S4
    By wanted198 in forum General News & Discussion
    Last Post: 09-09-2013, 02:46 PM
  4. Battery Life on S4 Wasn't As Good As Before
    By Vince2133 in forum Samsung Galaxy S4
    Last Post: 09-09-2013, 09:18 AM
  5. S4 active i537 custom rooms
    By phanks1972 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 09-08-2013, 03:49 PM
