Need help selecting a case. One with a belt clip
grendizer
7
Hi all
I have a S4, and I'm looking for a case/holter that has a belt clip, because the phone is too big in my pocket.
Right now I'm using the official Samsung protective cover, and I protect the front with an Invisible Shield. Right now this is the perfect size I want for my S4.
Is there a holster that fit the original Samsung Protective cover? That would be the best.
I went to a store and looked at a generic leather pouch. It was bulky and the attach didn't swivel. Also it was not a perfect fit.
As for cases that comes with a belt clip, I saw Otterbox Defender and Ballistic Case SG MAXX. They look great, but they are big. Also I don't need as much protection. My choice would be the Ballistic, but without the front cover.
The only slim case I found with a belt clip is the Seidio, but it's very ugly, to my liking.
So maybe you guys can recommend me a case or holster that will fit me need. Something that will protect the phone without too much bulkiness, or simply a pouch that is a perfect fit for the phone with the genuine case.
Thanks all for your time and response.
fantom305
548
I have a belt pouch that I bought when I had my S3 and it does fit my S4 even with the slim cover even thought I don't use the cover. I bought it at Verizon because TMobile did not have it but I didn't care from where as long as it fitted my phone, and it swivels.....I don't know if that could help you.
grendizer
7
The one in the Seidio line I don't like is the Surface. I really don't like the design.
The Obex seems perfect, seems quite slim, and also has an optional belt clip, but it's 90$+.
grendizer
7
Unfortunately I live in Canada, and Best Buy don't have the Platinum Case.
Right now the best one seems OBEX. It's expensive a bit, but it should last at least 3 years. But I fear for the sound quality.
