Bashkov
Re: Micro SD Card Corruption Issues
Hi!
After writing the post last night I decided to put a large quantity of stuff on my Micro SD Card, did this via the PC and left my phone out of it. I stuck 32gb of data onto the card, and this morning I couldn't access it, even in my PC. Now it's bringing to light that my issues are likely with the card, which for me is good news. Easy enough to replace eh!?
Anyway I am currently running H2Testw, on the card, to see how it goes. Hopefully I've been sold a scam card and I can just return that to Amazon!
Another thing to mention was the type of formatting your cards are using? My card is using an 'exFAT' formatting system, which is used on flash drives above 32gb. The Galaxy S4 IS compatible with this formatting system however seen as you are using a 32gb card I see no reason why you should be using exFAT. Instead you should be using FAT32. If you plug your Card into the PC and right click and hit Properties, a little window should open. Look for 'File System' if your card is exFAT try formatting it to FAT32. (No idea if this will help or not, but defiantly worth a shot!) Also If your card is formatted to NTFS, that needs to be changed too.
Also, when formatting you can change the allocated block size, from 512 bytes to 64 Kilobytes, this basically means how much data can be stored on one block. If your putting big files on then it might be appropriate to change the allocation size, however files like pictures and songs (2-3mb) shouldn't really need anything higher than a 4kb block. It might be worth playing around with that. Maybe try increasing the allocation size all the way to 64KB, I suppose there are not going to be any files smaller than that as it's a bloody 13mp camera! XD
Something a friend mentioned a few minutes ago was to try formatting it with a program called, HP USB Disk. He seemed to think that was more reliable. He was having issues with his card, and formatted it using that. That seemed to work for him. They were not the same issues, but that's worth a bash too. You can download it from PCWorld website. I'll be testing that out after I've verified the amount of legitimate space on my card. (Won't be for another 5-6 hours yet as it's a 64gb one! But I'll get back to you later tonight.)
Cheers!
Hi!
Cheers!
