Is this normal? Screen is always at 50-60% brightness or lower (full brightness hurts my eyes). Just curious because I'm not sure if I'm doing something wrong.
Sent from my VZW S4
Sent from my VZW S4
Post a screenshot of the battery stats. Although it sounds high, it depends how long the screen is on (time) related to what else is using battery. Are you seeing unusual battery usage?Is this normal? Screen is always at 50-60% brightness or lower (full brightness hurts my eyes). Just curious because I'm not sure if I'm doing something wrong.
Sent from my VZW S4
Sent from my VZW S4
The screen is big, and it takes a lot of power to light it up. Also keep in mind that whenever you go into the battery stats, that percentage is off of what you have used. So, if you are at 50%, and your screen brightness is 50%, really 25% of total power is from your screen.
It does seem like battery is draining fast. I did a factory reset tonight so I'm hoping it helps? Just got phone yesterday after exchanging it with a different phone. So hoping this is not an issue.
Ahhh didn't know that. Thank you! It makes it seem better knowing that lolhttp://img.tapatalk.com/d/13/09/27/eseby6y9.jpg
Sent from my VZW S4
Also, for the best health of your battery, try to plug it in about 25%. You don't want to drain it so low very often.
I will do that! Thanks so much
Sent from my VZW S4
