Help! There is a dead android laying on his back with an exclamation point that says "No Command"
Hoya Zoya
What does it mean when your S4 has an image of the android dead with his stomach open and an exclamation point over him, and the message "No Command" There are blue lines of text and yellow lines of text on the upper right corner, but they are too small to read....
Taking out the battery and restarting do not help.:(
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
Re: Help! There is a dead android laying on his back with an exclamation point that says "No Comman
Sounds like you are in the recovery menu.
Could you provide a picture?
Sent from a 4.3 Slim S3 using the AC forums app
Bosbouer
1,175
You are in the recovery mode. Use the volume up button the highlight reboot now, then press the power button once. Do not hold it in. It should boot normally
Roy Mustang
87
In the recovery mode the volume keys are used for navigating and the power button is used for making selection.
This mode does not have touch functionality.
Navigate to the reboot option using volume up and down keys and then use power button to select reboot and you will be good to go.
julieharrison
