1. Hoya Zoya's Avatar
    What does it mean when your S4 has an image of the android dead with his stomach open and an exclamation point over him, and the message "No Command" There are blue lines of text and yellow lines of text on the upper right corner, but they are too small to read....
    Taking out the battery and restarting do not help.
    09-30-2013 11:44 AM
  2. Golfdriver97's Avatar
    Sounds like you are in the recovery menu.
    Could you provide a picture?
    Sent from a 4.3 Slim S3 using the AC forums app
    09-30-2013 11:54 AM
  3. Kevin Robles's Avatar
    Help!  There is a dead android laying on his back with an exclamation point that says "No Command"-photo-27-04-2014-23-39-34.png
    How can i fix this sir?
    08-09-2014 11:54 PM
  4. Bosbouer's Avatar
    You are in the recovery mode. Use the volume up button the highlight reboot now, then press the power button once. Do not hold it in. It should boot normally
    08-10-2014 12:00 AM
  5. Roy Mustang's Avatar
    In the recovery mode the volume keys are used for navigating and the power button is used for making selection.
    This mode does not have touch functionality.
    Navigate to the reboot option using volume up and down keys and then use power button to select reboot and you will be good to go.
    08-10-2014 12:12 AM
  1. TMobile G2 on AT&T?
    By huntnyc in forum T-Mobile LG G2
    Last Post: 02-21-2014, 03:26 PM
  2. Preordered from AT&T? You should have your phone on October 1st
    By NJRonbo in forum Samsung Galaxy Note 3
    Last Post: 10-01-2013, 09:43 PM
  3. Is my s3 dead?
    By Daryl Brown in forum AT&T Galaxy S III
    Last Post: 09-30-2013, 03:20 PM
  4. Unresponsive Touchscreen upon Wake Up. PLEASE HELP!
    By Isabella17 in forum Samsung Galaxy Ace
    Last Post: 09-30-2013, 02:48 PM
  5. Galaxy Note 3 - Help with hand writing text...
    By kkhushi in forum Samsung Galaxy Note 3
    Last Post: 09-30-2013, 11:00 AM
