1. Teddy Jenkins's Avatar
    Hi,
    Over the last 2 days my S4 has really been acting up. I cannot find any reason why as I have not changed a single thing on it.
    so here is he issue(s)
    For starters, my battery is draining really fast but cannot find out why, Google Services has been at around 72% of battery used.
    Also, another issue is me holding the home button to close or change app. When I hold the home button it says "no recent apps" when clearly there are. so I hold it again and they all reappear. sometimes when I do close the app by sliding it to the side it sort of pushes the others that are open downwards really hard and fast instead of the normal sliding down to the next one and like I said sometimes they just aren't there as if I haven't launched anything. (I hope that makes)
    so take a look at the pictures below and tell me what you think.
    10-02-2013 08:17 AM
  2. BKKunz's Avatar
    Same here. I usually get 3 days of battery life and all of a sudden I got 6 hours. Google Services did a number on my phone.
    This phone is my backup and I hardly ever use it and that's the reason I get 3 days or more of battery life.
    My work phone is an iPhone 5 and I haven't had any issues with it.
    Hopefully an update will fix some of these issues. It's a fabulous device.
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    10-02-2013 08:31 AM
  3. STSVA's Avatar
    Google Services can be a number of things. Do you have Location Services turned on or off (the mobile data/wifi option for Location Services will show up as Google Services under Battery in Settings)? What are you doing to control syncing of Google apps? Have you turned off "Access my location" for Google apps?
    10-02-2013 09:31 AM
  4. Teddy Jenkins's Avatar
    Yes I have turned location settings off. Even in Google maps I have reinstalled the updates and cleared cache and turned the location seems of there as well. I have no idea what's happening.
    Restarted it several times and nothing.
    my shiney new S4
    10-02-2013 04:21 PM
  5. STSVA's Avatar
    my shiney new S4
    Have you used the Google settings app to turn off access location for all Google apps? Have you ever used Google Now; if so, are you sure it's off?
    Sent from my SCH-I545 using AC Forums mobile app
    10-02-2013 05:27 PM
  6. jmosher2's Avatar
    I began having the same battery drain issue two days ago - the battery went from 84% to 22% in about 3 hours with it sitting idle. I finally rolled back Google Play Services to the factory default and now the battery drain issue seems to have been fixed! At least for now.
    Teddy Jenkins likes this.
    10-03-2013 10:40 AM
  7. paintdrinkingpete's Avatar
    Google Play services seems to be acting funky lately...the Play store itself was down for several hours last night.
    My advice, clear the data from Google Play Services* and then reboot your phone. If that doesn't work, try uninstalling updates from Google Play Services.
    *Go to "Options" --> "More" (tab) --> "Application Manager" --> swipe right to get to "all", then scroll down to "Google Play Services"
    10-03-2013 10:52 AM
  8. Tsepz_GP's Avatar
    Oh dear, Google really have messed up this time, this seems to be a huge issue with many Androids.
    Okay, here's what you should do:
    Go to Settings -More tab -Location Services -uncheck WiFi & Mobile network location. Restart the phone afterwards if you want and the just keep an eye on the battery life.
    Hope that helps.
    10-03-2013 12:41 PM
  9. Teddy Jenkins's Avatar
    Thanks guys for your input - I did all of the above - Cleared data on Google services - turned location settings off and the on - I did the same in Google now and in Maps. I uninstalled maps then reinstalled it.
    Took a few hours to notice it but everything went back to normal and wakelocks started kicking in.
    Google really need to sort this out.
    Many thanks guys.
    10-04-2013 09:49 AM
  1. Replies: 3
    Last Post: 01-02-2014, 07:09 AM
  2. Galaxy S4 Charger/Cable Not Working - Help!
    By MrGalaxyS4 in forum Samsung Galaxy S4
    Last Post: 10-02-2013, 01:27 PM
  3. Active Notifications and Sound
    By gsp3 in forum Moto X (2013)
    Last Post: 10-02-2013, 12:30 PM
  4. Switching From Note 2 to S4 Question
    By chuckawd in forum Verizon
    Last Post: 10-02-2013, 09:56 AM
  5. Calhoot-A social calendar for your friends, family and fans. Never miss out
    By paulechols in forum Software Development and Hacking
    Last Post: 10-02-2013, 06:01 AM
