1. Vdmman's Avatar
    I have my screen on lowest brightness, use internet and games for 1 hour 30 minutes each day and my phone idles for about 3/4 of the day. Goes down at least 2 percent every 3-5 minutes? Is this normal? Help! Ps only have wifi mobile data sync and power save on.
    10-02-2013 06:14 PM
  2. UJ95x's Avatar
    Not normal, you might have a defective battery/phone or something is eating up your battery. Try a factory reset or downloading an app called Wakelock detector. A wakelock keeps your phone from going to sleep ans it kills your battery.
    10-02-2013 09:26 PM
  3. UJ95x's Avatar
    Also, how is the coverage in your area? If you have low signal it could cause your battery to drain faster. I can get from 4-5 hours of screen time in a day on my S4 so I'm thinking your phone is doing something wrong.
    10-02-2013 09:27 PM
  4. Vdmman's Avatar
    Uh usually 3-5 bars. And also I will download it. Too late to trade back phone, so if its defective im going to scream.
    10-03-2013 03:14 PM
  5. UJ95x's Avatar
    That would suck, my phone on lowest brightness uses 60+% of the battery but I can get 4-6 hours depending on my usage. I got 5 and 2 minutes yesterday and I'm on pace for 5 and a half or about that today. I would recommend you download Juice Defender, just started using it and it increased my screen time by about an hour.
    10-04-2013 01:10 AM
  6. Vdmman's Avatar
    I tried wakelock detector. Nothing important is going on in the backround...
    10-04-2013 03:38 PM
  7. Shanicenicolle's Avatar
    Make sure you have the system processes turned on to see if its a rogue system app.
    Sent from my *PURPLE* Galaxy S4
    10-04-2013 08:17 PM
  8. Vdmman's Avatar
    Google+ is 18 minutes 37 seconds on cpu wakelock. Also on wakelock triggers google search is 7 times. Is this good or bad, none of this makes sense to me.
    Sent from my red s4 with horrid battery life. Want a screenshot, how do I show you? You guys might understand better with a screenshot.
    10-04-2013 09:51 PM
  9. Vdmman's Avatar
    I also turned on system process cpu wakelock and android system is 239 times. Whoa is that bad?
    10-04-2013 09:54 PM
  10. Shanicenicolle's Avatar
    Expand that and take a screenshot.
    10-05-2013 12:00 AM
  11. Vdmman's Avatar
    I dont know how to post pictures. How do you?
    10-05-2013 04:59 PM
  1. Over Saturated Screen Color, Any fix?
    By wpramono in forum Moto X (2013)
    Last Post: 10-03-2013, 09:31 AM
  2. Stock music player problem
    By dbibby88 in forum Samsung Galaxy S3
    Last Post: 10-03-2013, 02:47 AM
  3. Any idea on how many stores will get?
    By sddabrow in forum Samsung Galaxy Note 3
    Last Post: 10-02-2013, 09:04 PM
  4. Stuck on logo boot and can`t go into recovery!
    By streetbond in forum General Help and How To
    Last Post: 10-02-2013, 08:18 PM
