09-08-2016 05:41 PM
33 12
tools
  1. Mohaymen Shoaib's Avatar
    I really Need Help! I bought Samsung Galaxy S4 (GT-I9500, Made in Vietnam) from Kogan Australia in August then I left Australia and going to live overseas for a while. For last 4 days I am experiencing really strange battery draining issue. My phones battery drains down to 0% (mentioning battery critically low) and turns off by itself. This happened almost everyday for last few days even when my phone battery had over 85% or 60% or 40% charge left. After took the battery out of the phone and then re-inserted and re-booted, it still shows battery critically low. Then I did a factory reset on my device and I am still experiencing the same problem. It is also important to note that, yesterday after the phone turned off by itself by showing battery critically low (in reality it had over 85% charge left), I left it off for a while without plugging it in for charge. Then I turned it on again after a while, and the the phone rebooted fine and was working fine with almost 70% charge. I have been using this phone for only 2 months and I take really good care of my phone. I am not really sure what the problem is and now that I cant send it back to Kogan, I am really worried and frustrated. Is there any way to solve this problem or any suggestions. PLEASE KINDLY HELP!!!!!
    MASHRAFLK likes this.
    10-03-2013 05:18 AM
  2. Haalcyon's Avatar
    Welcome to the forums, it's good to have you here!
    There could be several causes for such behavior. You could have a bad battery. Something could be running up your CPU and causing the battery to drain quickly, but your phone would probably be getting hot too. If you're phone is not getting good signal it could be spending some power trying to 'phone home'. Are you able to post a screen shot of your battery life (power+home)?
    10-03-2013 06:13 AM
  3. Mohaymen Shoaib's Avatar
    But my phone battery does not actually drains to 0%, even though it shows 0% with battery critically low notification. If I leave my phone switched off for a while and then switch it back on, battery comes back to normal state showing the actual remaining battery charge and everything works just fine. its jus that randomly out of nowhere the phone reboots automatically and shows 0% battery after the boot. As I mentioned earlier I even did factory reset and didn't install any other app and same problem happens again. Default apps under factory reset condition should not drain battery (in fact battery is not draining at all)
    10-03-2013 10:23 AM
  4. STSVA's Avatar
    I think I'd try a new battery; they're generally not too expensive, but that might vary depending on where you are in the world and the available sources.
    10-03-2013 10:48 AM
  5. Haalcyon's Avatar
    You're correct, this shouldn't drain the battery. However, the battery (or the phone) could be misreporting. I would still consider trying another battery, especially since they're relatively inexpensive and it can't hurt to have a spare. You could try re-flashing the factory ROM just in case some issue in your existing ROM is the culprit. Your could also contact Samsung directly for warranty assistance.
    Note 8.0 via Tapatalk IV
    10-03-2013 10:51 AM
  6. ladyhaly's Avatar
    Go to your phone dialer and input *#0228#. It should launch this:
    Hit Quick Start. It should recalibrate your battery and show you your real battery level. If it shows a value you don't expect, that is the real charge on the battery and not what you thought it had. Charge your battery to 100% again.
    If this doesn't work, you have a bad battery. Claim your warranty from Samsung. Not the store... Samsung Service Center should do it as long as you have proof of purchase and warranty statement.
    If not, buy a new Samsung original battery. Don't skimp out and buy one of those cheap knock offs as there have been reports of phones all across brands exploding or causing other injuries because they used non-official third party batteries.
    Sent from my GT-I9505 using Tapatalk 4
    10-06-2013 03:02 AM
  7. debsawyer's Avatar
    You are not alone. I have 2 extra batteries. I use Google Music for 3 hours everyday during my workout and my battery is dead by the time I get home. So I switch battery at least once a day. I purchase two extra batteries from Samsung, the ones with the charger case.
    10-06-2013 09:29 PM
  8. MASHRAFLK's Avatar
    I
    Hello shoib bhai..I am facing the exact problem since yesterday. Could you please help me out if you had the solution for your problem
    - - - Updated - - -
    I
    10-16-2013 11:41 AM
  9. MASHRAFLK's Avatar
    - - - Updated - - -
    PROBLEM SOLVED ! CASE OF BATTERY SWELL.. REPLACED WITH A NEW BATTERY AND PHONE WORKING FINE..
    10-28-2013 06:24 AM
  10. TaMaTeM's Avatar
    So, replacing the battery will solve that problem? It's that simple?
    I bought my phone on October 25 and it gone crazy that way 3 days ago, and I'm losing my mind because of it. My warranty works only in KSA and now I'm in Egypt!
    12-09-2013 11:57 PM
  11. DMF2013's Avatar
    Ive been having the same problem and I do not know why. I am still researching the purpose of the update.
    12-12-2013 11:41 PM
  12. rafis's Avatar
    Similar issue, but in my case battery drains even when the phone is turned off. I don't thing thats normal and thats why I haven't replace my battery for a new one, I'm affraid it might be some issue with my s4 mini. Battery drains out cold... I've had my s4 mini for 3 weeks. It started with the symptoms a week ago. I have tried almost everything.
    12-28-2013 10:34 AM
  13. STSVA's Avatar
    That sounds like a battery problem - I'd replace the battery if I were you.
    Sent from my SCH-I545 using AC Forums mobile app
    12-28-2013 01:38 PM
  14. rafis's Avatar
    I already did. The new one drained the 54% it came with in less than 2.5 hrs... thats not right also. Don't know what else to do
    12-28-2013 03:51 PM
  15. STSVA's Avatar
    What does the phone say is using the battery?
    12-29-2013 01:16 PM
  16. rafis's Avatar
    OS and basic apps from android. The real problem is that drians out cold when the phone is even off... I have to " literally" jump start the battery with an outside batt charger... so it can use the regular Samsung charger
    12-29-2013 01:33 PM
  17. STSVA's Avatar
    If the phone is really turned off, then I think you have a second bad battery. You might try charging the battery, then remove it from the phone. Put it back in after a day or so, and see if it drains when not in the phone. If it does, that's a bad battery for sure.
    12-29-2013 02:41 PM
  18. rafis's Avatar
    I alrready did that test and it doesn't drain. The battery is not the problem.
    12-29-2013 03:43 PM
  19. STSVA's Avatar
    When you say the phone is turned off, do you mean really turned off, or asleep?
    12-29-2013 04:28 PM
  20. Vix8380's Avatar
    Hi I have the solution guys!!!! No ody BUY anymore batteries or change any settings its a common fault with the S4 I had the same fault it woukd have say 70% battery switch itself off come bk on with 2% battery and sometimes it would just go bat crazy on me a d switch itself off and on constantly like it was persessed.
    Anyway after many many google searches I took it to my nearest samsung warranty repair store (they are nationwide and as they get 2 yesrs warranty all free my local store was manchester arndale) as soon as I sat down in store and said I had an S4 she knew straightaway what my issue was she asked me is it switching itsekf off and on etc she then proceeded to tell me its a common fault with the s4's and Samsung have admitted the flaw but 2 many sold to do a recall so ry on ppl turning up at the samsung repair shops to get it fixed she said its a battery fault took my battery out and it was all swelled up she said it needs new battery and charger unit inside phone has to be replaced I waited while they did it no exaggeration it took no more than 5 mins and has been working fine since.
    She did say they are getting 100's of people turning up with s4's all same issue.
    I bought my phone in mid june issue arose end Oct had it repaired end of October and so far so good she did say once charger unit and battery replaced thats it issue sorted it shouldn't happen again.
    Google your nearest samsung repair shop and just take it in even if it turns out to be something else (which is highly unlikely) your sr is under warranty so they will fix it for free either there and then no sending it off and waiting for weeks or if they busy might tell you to come back in an hour.
    Good luck Vicki :-)
    01-10-2014 04:56 AM
  21. peejay1977's Avatar
    I had the same, phone started getting hot when charging and eventually would turn itself off when at about 70% and get caught in a reboot loop. Local phone shop replaced the battery under warranty as I noticed it had swelled. Apparently Samsung are aware of a bad batch of batteries.
    01-10-2014 05:53 AM
  22. sjsmith1708's Avatar
    There is a fault with the batterys on the s4 that samsung are aware of. I poped in to the pho e sjop where I had my s4 from and they sent me a new battery within days of going in free of charge
    01-10-2014 06:08 AM
  23. Macusman's Avatar
    Salaam to all . I own Samsung S4 . when i charge it , after 10,15 mins it shows battery full notification but when i unplug and then plug it again then it shows charging .. i have to repeat it for several times if i dont then battery shows 5 % after 10 min of use ....
    Pls any one who know how to fix it ?
    02-02-2014 03:43 AM
  24. Macusman's Avatar
    02-02-2014 11:44 AM
  25. Macusman's Avatar
    Pls any one who know how to fix it ? Note : Battery is brand new
    Arham Ibrar likes this.
    02-02-2014 11:46 AM
33 12
  1. Replies: 12
    Last Post: 10-10-2013, 01:45 PM
  2. General compatibility question with Google Play on tablet
    By justanotherguy in forum General Help and How To
    Last Post: 10-03-2013, 10:05 PM
  3. Oficial Samsung Charger compatible with anker 5200mha battery?
    By Nuno Mota in forum Samsung Galaxy S4
    Last Post: 10-03-2013, 12:02 PM
  4. transfer all info from S4 to Note 3
    By gumbyr1 in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 10:52 AM
  5. Samsung Galaxy S3 not getting recharged!
    By Divig in forum Samsung Galaxy S3
    Last Post: 10-03-2013, 01:39 AM
