10-12-2016 03:29 AM
27 12
tools
  1. crazylaughter's Avatar
    The brightness controlled on the drop down menu on my s4 disappeared. Anyone know how to get it back?
    10-04-2013 11:28 AM
  2. SpookDroid's Avatar
    Go into Settings, My Device tab, select Display, and then Notification Panel. The option to have it show or not should be there.
    10-04-2013 11:46 AM
  3. crazylaughter's Avatar
    Thanks that was driving me nuts
    SpookDroid likes this.
    10-04-2013 12:21 PM
  4. De-Angelo Rollison's Avatar
    Thank you
    03-09-2014 06:30 AM
  5. Felim_Doyle's Avatar
    Notification Panel is checked in my Display Settings but even if I toggle it off and on again it does not reappear. This change may have occurred since updating to Android 4.3 but I've just noticed it now. Any more suggestions?
    Sent from my GT-I9505 using Tapatalk
    03-25-2014 07:31 AM
  6. msndrstood's Avatar
    Reboot and battery pull has worked for others. Good luck! 🍀
    Sent via The Big, Bad, Beautiful Note 3
    03-25-2014 08:32 AM
  7. Sprytech's Avatar
    My brightness slide bar disappeared after I did a reset. I toggled and rebooted and it hasn't returned. A few other things aren't quite right. The phone reset to 4.2.2 so once they push the new and improved 4.3 things may look better.
    04-06-2014 06:12 PM
  8. YragTtocs's Avatar
    I noticed after the kit kat update when the battery gets low, the brightness toggle in the notification bar disappears! It must be part of the power saving so you can't manually put the brightness up when your really low on battery! It confused me for days wondering where it kept going!!
    Sent from my GT-I9505 using AC Forums mobile app
    04-06-2014 07:13 PM
  9. Felim_Doyle's Avatar
    Well my brightness bar is back but I'm not sure why. I suppose it may have been the low battery issue but it was a problem for several days and I had recharged in between.
    Lots of odd things happening since updating to 4.3 including eating battery power and running hot but my memory (RAM) and internal storage are low too so it could be that.
    Still investigating!
    04-08-2014 11:25 AM
  10. Shawn Li's Avatar
    I have the brightness control problem on my note 3.. I can't get it to work at all.. not with all solutions provided above.. toggle it on and off, + reboot doesn't work.. trying to take out the battery doesn't work either.. :S anyone know why?
    04-23-2014 08:44 AM
  11. Pa Ap's Avatar
    Experienced a similar problem on Samsung Galaxy Ace 2. Try this:
    1. Plug in charger and start recharging your 'phone. (If the brightness increases almost immediately, you know it's a power-saving setting that's causing the problem, which now becomes easy to rectify; no need to power off/on or remove the battery.)
    2. Go to Settings and look for Power Saving options.
    3. In those options you should find a Customize option, which enables you to adjust or deactivate the default low-power behaviour, which by default dims the screen *and* disables the Brightness control in Settings until you recharge the battery. (IMO that's stupid: WHAT IF you need to use your 'phone to make an emergency call, low power or not, but you can't see the screen?)
    Felim_Doyle likes this.
    05-29-2014 04:12 AM
  12. Shubham Shelar's Avatar
    please help me there are cant work the brightness adj. in notification panel PLEASE HELP ME
    05-31-2014 10:23 AM
  13. Shubham Shelar's Avatar
    i have same brightness control problem on my sam. g. s.4
    05-31-2014 11:37 AM
  14. niralasatya's Avatar
    Open your video player, start a video, adjust brightness, exit.
    I did this having mx player and it worked.
    Hope it helps. :-)
    tobbbie4tobbbie likes this.
    08-25-2014 11:00 AM
  15. Ihab JAMLI's Avatar
    Go
    1- setting
    2- device
    3- Notification panel
    4- brightness adjustment
    09-08-2014 06:48 AM
  16. nl-x's Avatar
    Hope it helps. :-)
    Thanks a lot! This was driving me crazy!
    11-23-2014 05:28 PM
  17. Narayana Swamy Reddy Parlapalli's Avatar
    Hope it helps. :-)
    Thanks dude !!!
    12-20-2014 04:48 AM
  18. reinierf's Avatar
    Hope it helps. :-)
    This is the only thing that worked for me. Thanks a lot!
    01-13-2015 01:07 PM
  19. tobbbie4tobbbie's Avatar
    Thanks (done) - this works as well. In another thread is was the Night Mode app recommended. I think it is any app that takes and releases control for brightness properly which should do here.
    02-25-2015 08:05 AM
  20. techdude49's Avatar
    I have a Galaxy S4 and this was driving me nuts!!! The ONLY thing that worked (after trying all the suggestions) was going into MX Player and adjusting the brightness.
    Thank you!!!
    03-16-2015 09:25 PM
  21. msceete86's Avatar
    Thank you!! This was the only thing that worked for me as well! I appreciate the help!
    05-20-2015 11:26 AM
  22. msceete86's Avatar
    Thank you! This was the only thing that helped! You're awesome!! : )
    05-20-2015 11:27 AM
  23. James Smith42's Avatar
    Plug in the phone and then check while your cell phone is plugged in. My phone did the same thing because when its battery was low. Good luck!
    09-14-2015 06:53 AM
  24. simplykartik07's Avatar
    Try uninstalling c cleaner or any similar app to regain drop down brightness control.
    02-26-2016 06:41 AM
  25. VICTORIA AMIRA MEYENBERG's Avatar
    Thank you! It was Very helpful ! I got it !
    06-21-2016 07:53 AM
27 12
  1. SGS 3 - How to change Font on Outlook Email Client?
    By cboshdave in forum Samsung Galaxy 3
    Last Post: 11-21-2013, 09:34 AM
  2. SGS 4 Google Edition - Display Profiles - AMOLED Saturation / Calibration
    By Vince Klein in forum Samsung Galaxy S4 Google Edition
    Last Post: 10-05-2013, 06:48 PM
  3. Data erase help!! Galaxy Mega 6.3
    By aflack23 in forum General Help and How To
    Last Post: 10-04-2013, 03:33 PM
  4. Data erase help!!
    By aflack23 in forum Samsung Galaxy Mega 6.3
    Last Post: 10-04-2013, 09:35 AM
  5. Help- Issue with Nova Launcher
    By leathernuts#WP in forum Verizon LG G2
    Last Post: 10-04-2013, 09:23 AM
