1. MaxGunner's Avatar
    My calendar is showing the forecast / weather info for a previous location. I've changed the zip code on Google Calendar and it's showing correctly there, but on my S4 it's still showing the other location. I can't see where to change that. Can somebody point me in the right direction?
    thanks,
    MG
    10-06-2013 11:35 AM
  2. Megg87's Avatar
    Was this issue resolved? I'm having the same annoyance...
    02-11-2014 06:02 PM
  3. mhinc's Avatar
    Try going into;
    SETTINGS > MORE > LOCATION SERVICES
    Do you have "Access to my location" and "Use GPS Satellites" on? If not this could be causing the issue. Try turning both on and see if your location updates.
    02-12-2014 03:57 PM
  1. SGS 4 - Can't transfer files or data from pc to micro SD card ?
    By MrSourGit in forum Samsung Galaxy S4
    Last Post: 08-01-2015, 05:59 AM
  2. How do you display weather on lock screen?
    By semp1 in forum Samsung Galaxy Note 3
    Last Post: 11-02-2013, 12:53 PM
  3. How to get 4.1.2 camera effects on my 4.0.4 camera
    By patsum in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-07-2013, 12:42 AM
  4. Replies: 1
    Last Post: 10-06-2013, 10:09 PM
  5. Replies: 1
    Last Post: 10-06-2013, 09:43 PM
