Results 1 to 10 of 10
    damnLED's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung S4: Blue LED always on
    This is driving me insane. The blue LED on my S4 is always on, including when I have turned the phone off (not connect to a power source, off for 15minutes, LED still present).
    I have disabled all the LED notifications and I am out of ideas. Odd though it may seem, it is very bright at night and I'd like it gone. For good.
    Does anyone have any idea how to fix?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Samsung S4: Blue LED always on
    Quote Originally Posted by damnLED View Post
    So the LED is still on even when the device is shut off (power off menu)? Or do you mean when the device is locked and screen off?
    If it's still on with the screen off (powered on) then there is a setting you missed that needs to be disabled.
    damnLED's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is still on when the device is shut off via the 'power off' menu.
  4. #4
    WhiteiPadMini's Avatar
    Posts
    Global Posts
    374 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does the problem still occur when you pull out the battery?
    damnLED's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I took the battery out and the blue LED went out but the moment I put it back in, before I had even turned the phone on, the blue LED was back on. The battery was out for at least 1 min.
  6. #6
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It sounds like something in the phone is broken. You'll probably have to have it repaired under warranty.
  7. #7
    hedo44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have Samsung s4 and facing the same problem since the moment i bought it,and want to know if you got any ideas about it?!
  8. #8
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If the light is on when the phone is off then my guess would be that it's either a short on a board somewhere or a bad transistor. It's very unlikely that you'll be able to fix it yourself.
    Sent from my SCH-I545 using AC Forums mobile app
  9. #9
    Niko Peregrino's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have the same problem but mine is green. how's your device now? is it okay now and what did you do? thank you in advanced
  10. #10
    LEDwtf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having exactly the same problem which only started this morning. I have had the phone for 3 months and have not had any issues until now. I will be booking the phone in for repairs as Im sure its not a software setting.
  1. Galaxy Tab GT P1000 - samsung tab is STUCK. PLEASE HELP
    By quakquakquak in forum General Help and How To
    Last Post: 10-24-2014, 10:18 PM
  2. S4 syncing old emails - why can I not fix this easily???
    By Carley Barter in forum Samsung Galaxy S4
    Last Post: 04-06-2014, 02:11 PM
  3. T-Mobile LG G2 - Not getting Hangout notifications on G2 at all
    By joshua.worth in forum T-Mobile LG G2
    Last Post: 10-10-2013, 07:50 PM
  4. Replies: 1
    Last Post: 10-07-2013, 07:34 PM
  5. Replies: 2
    Last Post: 10-07-2013, 10:51 AM
