Welcome to Android Central! Looks pretty normal to me. Battery life depends primarily on the size of your battery and how much the screen is on (since that is by far the biggest energy user). Some apps can really be a battery drain, but that amount of use by Chrome probably isn't too surprising if you've been doing a lot of web surfing.
What device do you have, and can you post your screen-on time?
