I have several mini USBs cables and a bunch of USB to AC adapters. Any time I use any of these (Or even add my USB extender in between the cord that came with the phone and the port that came with the phone) it says it's connected and charging but continues to drain the battery. The same thing happens even if I use the cable that came with it through the USB ports on my computer. The ONLY way it will actually charge is if I'm using the original cable AND the original adapter.
Should I be returning this phone for another? In this day and age, with as many options as we have for charging, I should be able to charge it at work and in my car without using the cables it came with.
Any input would be appreciated.
