1. Niko Peregrino's Avatar
    hi guys. please help. the green led on my SGS4 is always there even when the device is off. how can i solve this problem. thanks in advanced guys. GodBless
    10-23-2013 06:13 AM
  2. keifusrahn's Avatar
    If you have notifications that you havent cleard it will stay on or If you are using any apps that utilize the LED for notifications, this happens unless you specifically go into LED Blink Rate and change it from Always On to Slow/Medium/Fast etc.download LightFlow from the play store and you will find the LED Blink Rate set to 'Always On' by default. Change it and it should go away. Let me know if it works
    Niko Peregrino likes this.
    10-23-2013 06:40 AM
  3. Niko Peregrino's Avatar
    Hmm okay i will try it. But when i bought the device its not like that. It started when i accidentally drop the device into water for 4-6seconds. After 2 weeks since the incident it just happen that the led is always there even when there is no apps or notifications. Thank you
    10-23-2013 10:04 AM
  4. Niko Peregrino's Avatar
    I tried the light flow. Nothing happens. It still there.
    10-23-2013 10:25 AM
  5. keifusrahn's Avatar
    That sounds like what the problem is probably the only way to fix that is taking the phone apart and cleaning the rust off the board "NOT RECOMMENDED" unless you have experience doing so your proly gonna have to just deal with it or you can find someone that can repair phones
    10-24-2013 06:19 PM
  6. VDashjian's Avatar
    Did you ever get the green light fixed? I have the same exact problem. Never goes off. Even if the phone is turned off or the battery is at 1 percent. LED stays green....
    Furthermore, I noticed the smart scroll doesnt work like it used to before this problem. It can no longer detect my face. Is it a coincidence or related issue? Have you noticed that?
    10-27-2013 11:41 AM
  7. keifusrahn's Avatar
    is it rooted?
    10-28-2013 02:46 PM
  8. VDashjian's Avatar
    Mine is not.
    10-30-2013 03:16 AM
  9. Niko Peregrino's Avatar
    the green led on my device is now fine. i brought it to samsung and let them replace it. they just replace the LED. hows your phone now? i suggest to bring it also to samsung and let them do the work. never try to open it.
    11-02-2013 11:11 AM
  10. TeaserTuesday's Avatar
    I believe he answered his own question when he said he dropped it in water.
    11-03-2013 02:04 PM
  11. hausjam's Avatar
    I haven't tried lightflow on my gs4 but when I tried it on my nexus 4 my battery life took a noticeable hit. So I avoid that app now. Which is a shame since I liked that it would alternate the flashing colors when different notifications were waiting. Not worth the battery drain though.
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    11-03-2013 03:45 PM
  12. yellowhue's Avatar
    Have you had the problem fixed? I've had the exact same problem with my Note 3 which I only purchased 2/3 weeks ago.
    11-07-2013 01:31 PM
  13. VDashjian's Avatar
    No I have not had it fixed. A good friend of mine suggested I take it to his shop and they will take it apart and clean it out completely. I really believe I got sweat damage because I use my phone to run and my armband is usually soaked by the time I am done.
    Also i noticed the camera quality is very grainy from what it used to be. I just need to make the time and go see him one of these days on an extra long lunch break. I will let you know what happens.
    BTW, did you mean you took it to ATT? because i dont know any samsung specific repair shops here in L.A. area
    11-08-2013 04:02 AM
  14. Casandra1975's Avatar
    Maybe it's not a phone problem, but a "I dropped my phone in water!" problem. I have the same phone. A regularly flashing green light, only while screen is off means I have unchecked notifications.
    04-03-2014 10:11 AM
  15. Heather McLean1's Avatar
    Its not flashing...its constantly on...they said it wont turn off even when the screen is black or the phone is turned off....I didnt drop my phone in water and I dont have sweat damage and my green light is constantly on...I have even tried a hard reset (removing the battery from my phone and replacing it) as soon and the battery is in place the green light comes on and is constant
    07-19-2014 12:19 AM
  16. Ckumarb's Avatar
    In my case as well, no water damage, no new software installed. Tried removing the battery, changing settings on the device [Settings>Device>LED Indicator]. The light just stays on.
    08-11-2014 06:51 AM
  17. Ckumarb's Avatar
    I had the battery drained to empty, to the extent that there was no power for the led light. Then placed the device for charge. The issue is resolved in my case. Hope it works for you folks as well.
    Good luck.
    08-11-2014 08:52 PM
  18. shandango's Avatar
    Good luck.
    10-18-2014 05:55 AM
  19. shandango's Avatar
    I had the same problem took hairdryer and blew hot air into earphone jack for about 30 seconds then waited about 5 minutes and light went out,now there is no light at all,find it better without light than constant green light being on
    10-18-2014 05:58 AM
  20. Kevin Barrier's Avatar
    Go back to a stock watch face. Worked for me. Night driver was the one that kept my green led on full time.
    04-02-2015 08:12 PM
  21. Aisha Saeed1's Avatar
    I didn't get that option in light flue! That green led is really bothering me a lot. Plz help
    06-12-2015 01:31 PM
  22. Damien Chavez's Avatar
    It just hapoened today
    10-27-2015 09:27 PM
  23. Shivashankar S's Avatar
    I too faced the similar problem after my note4 fell into water for 2 sec green light is constantly on plz someone give the best solution thanks
    11-23-2016 12:40 PM
  1. S4 slow motion video question
    By Trolled123 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-23-2014, 01:41 PM
  2. Help with tempered glass instillation
    By bprochon in forum Samsung Galaxy Note 3
    Last Post: 10-25-2013, 11:06 AM
  3. Auto Correct on Samsung keyboard
    By jmgilliam in forum Samsung Galaxy S4
    Last Post: 10-23-2013, 10:34 PM
  4. Frozen My Galaxy S2... Please help!
    By Heathathon in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-23-2013, 09:27 AM
  5. help google play store error RPC:S-5:AEC-0
    By Rameek Mckenzie in forum Google Play Store
    Last Post: 10-22-2013, 09:03 PM
