Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Maelliures
    tharangarox's Avatar
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry GALAXY S4 not detected BUT charging when connected to Machine
    I have encountered this problem after buying my new phone two days ago, when i connected the S4 to my PC it's only charging but not detecting as a MTP? mass storage mode, even in device manager of my PC it's not detected. but all other phones are working fine(my S3 and HTC EVO ).. pls help me guys
    P.S: I even activated developer mode and several times uninstalled both kies and drivers but nothing seems to help
    Even i downloaded latest drivers and installed still problem persists
  2. #2
    Maelliures's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: GALAXY S4 not detected BUT charging when connected to Machine
    it might be the setting part nt be done... let me check and c
    tharangarox likes this.
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Identified the problem , when connecting to windows7 piece of cake but problem still persists on windows 8
    Quote Originally Posted by tharangarox View Post
  4. #4
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    This would lead me to believe it's a driver issue. However, did you try a different USB port and a different cable?
    from a Note 3
    Posts
    Global Posts
    13 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes. tried different ports with 4 different cables but no improvement on windows 8
    Quote Originally Posted by Haalcyon View Post
    from a Note 3
  6. #6
    irishmikeh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You didn't answer how you fixed this problem. My Galaxy 4 Mini has the same problem. What did you do?
  7. #7
    ranajit saha's Avatar
    Posts
    Global Posts
    63 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by irishimeh View Post
    Try with another USB port of your PC which comes directly from the motherboard of your PC. It worked for me. I think it's the problem of USB version.
    Posted from Samsung Galaxy S4 (GT-I9500)
  8. #8
    alexcolka's Avatar
    Posts
    Global Posts
    192 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Assuming drivers updated, always connect phone with the home screen active, never in lock screen. If fails, then reboot phone connected to the pc, it should be detected now. Always work for me that way.
    Sent from my GT-I9500 using Tapatalk
  9. #9
    irishmikeh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you so much for your fast response & suggestions, sorry I got lost for a couple days. I am still unsuccessful, let me give you a little history. I purchased & received a new Verizon Samsung S4 Mini 4-6 weeks ago, running Android version 4.2.2. My 1st time with a "smart phone". Also purchased a 64G Micro SD card with arrived 3 weeks later. Never has my computer running the 32 bit windows 7 Pro recognized my phone while charging the battery through it. I have downloaded Kies 3 times, each time preceded by deleting all Samsung drivers. I have primarily used the USB cable provided with the phone, although have tested other cables with no change of effect. I use a USB expander giving me 6 extra ports, but was instructed to try removing it, then check the phone. Rebooted the computer this time only using 2 USB ports, one for the cable to hook up the phone with & one for the mouse, no change in results. I have even removed my micro SD Card to verify it would be recognised when inserting a a reader. The computer recognized this. As you can see by the length of time for me to respond, this issue isn't extremely high on my things to do, yet I do want results. I would appreciate any help or advice. Thanks. Mike
  10. #10
    Posts
    Global Posts
    63 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Then contact Samsung service centre or your carrier about this. Before that you try with another pc to make yourself sure if it's the problem of pc.
  11. #11
    irishmikeh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you again for your advice.
  12. #12
    bharatmalodiya's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  1. Camera fails after motherboard swap - Verizon Galaxy 3
    By kernhills in forum Verizon Galaxy S3
    Last Post: 12-09-2013, 10:55 PM
  2. Galaxy S4 Mini active on Verizon - Ask your questions!
    By iLLusive in forum Samsung Galaxy S4 Mini
    Last Post: 10-30-2013, 03:12 PM
  3. Replies: 2
    Last Post: 10-27-2013, 01:06 PM
  4. connectivity issues
    By hburbach in forum Samsung Galaxy S3 Mini
    Last Post: 10-27-2013, 04:06 AM
  5. Copied files to Nexus 7 - same size but content zeros
    By oceanclub in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-26-2013, 08:53 PM
