1. Osmund Baardsen's Avatar
    I use airplane mode at home because mobile reception here is poor, and because it saves battery when using the phone for other purposes.
    I don't know why, but when in airplane mode the wifi will not connetct -I get the message saying "obtaining IP address" and nothing more happens. If I turn airplane mode off - it connects right away. This is something that just happened a few days ago. Before that, everything was fine - I got wifi in airplane mode.
    I tried using static ip but that didn't help either.....
    10-28-2013 05:20 AM
  2. shanghaichica's Avatar
    You can't connect to wifi whilst in aeroplane mode.
    Posted via my Galaxy s4
    10-28-2013 05:48 AM
  3. ScottsoNJ's Avatar
    Yes you can
    10-28-2013 06:36 AM
  4. shanghaichica's Avatar
    Yes you can
    Well I thought that was the point of aeroplane mode. On all my devices when I switch aeroplane mode on it switches off wifi.
    mandoman28 likes this.
    10-28-2013 07:08 AM
  5. RageRoids's Avatar
    Same on iPhones you can connect to wifi even when Airplane mode is on.
    10-28-2013 08:34 AM
  6. tytlyf's Avatar
    When I turn on Airplane Mode it shuts off the networks. When I press the Wifi toggle in the notification pull down, it connects to wifi while still in Airplane Mode.
    10-28-2013 09:57 AM
  7. shanghaichica's Avatar
    I didn't know that. Thanks
    10-28-2013 09:58 AM
  8. JudH's Avatar
    There are apps in play store that allow you to toggle on/off whether airplane mode turns WiFi and Bluetooth off so you don't have to turn them back on. Not sure they work on 4.3 but they work great before that.
    10-28-2013 10:49 AM
  9. DM51's Avatar
    ... you can connect to wifi even when Airplane mode is on
    That's useful to know – thanks. I had the Gulfstream people fit the WiFi option in my G650, but I didn't realise the phone could use it in airplane mode. I've been using it in normal mode up to now. This may solve a problem I've been having with my pilot – she's been complaining about a high-pitched buzzing noise in her headset whenever I'm using the phone. Nice girl, but I'd like to put an end to her whining about this so I'll try it tomorrow.
    10-29-2013 12:57 AM
  10. ladyhaly's Avatar
    Using WiFi while in airplane mode doesn't seem so great then as it interferes with other connections. I wouldn't want any pilot compromised while flying just because I wanted to check Facebook.
    Sent from my GT-I9505 using Tapatalk
    11-01-2013 01:21 AM
  11. RageRoids's Avatar
    Wifi Isnt the issue its the cellular signal that supposedly interferes.
    Even then its debatable as ive been on many flight where people haven't switched their device but just put it in their bag.
    With some many flights around the world + mobile phones - if it really did make a huge difference we'd have planes falling from the skies.
    - - - Updated - - -
    Nice wish I had a Gulfstream lol
    jay_dubb2k5 likes this.
    11-01-2013 08:40 AM
  12. mahler9's Avatar
    Thank you. This is useful. I did not know you could still have wifi in airplane mode. I just tried it with the GS4 (with 4.3 update) and it works fine
    11-01-2013 09:36 AM
  13. sahil G's Avatar
    mry ipad py lock lg gya t gmail ki id mng ra h t airpain moda of hny ki wja se wifi b ni on ho ri nd gmail ki id b n i lg ri mai kia krn ab
    03-08-2014 04:46 AM
  1. Help! Lenovo IdeaTab A10000-T Stuck after Recovery Mode > Reboot System Now
    By Jan Villamor in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-25-2016, 06:39 PM
  2. Do we need antivirus with Note 3?
    By karan1389 in forum Samsung Galaxy Note 3
    Last Post: 01-18-2014, 11:43 PM
  3. hoe to get bleed light in Nexus 4
    By Harish Varma in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 11-06-2013, 02:00 PM
  4. Replies: 3
    Last Post: 10-28-2013, 10:47 PM
  5. Moving Music From Desktop To Phone And Freezing Issues
    By Jeff Stevens in forum Verizon Droid Incredible 2
    Last Post: 10-28-2013, 08:00 AM
