1. King Mustard's Avatar
    I have a 7500mAh extended battery for my S4 (i9505) and even the final 5% of battery lasts for a long time.
    However, the default behavior for the i9505 is to dim the screen (to the lowest setting it appears) when the battery reaches 5%.
    The volume bar disappears from the notification tray and you can no longer adjust the brightness in Settings.
    How can I stop this behavior?
    11-01-2013 07:42 PM
  2. ladyhaly's Avatar
    I'm not sure but try to go to Settings > My Device > Power Saving Mode and uncheck Screen Power Saving. This should theoretically prevent your screen from dimming when it gets to 5 percent battery now. But I haven't tried it out as I don't have a 7500 mah extended battery for my S4. Would you mind telling us where you bought it? I'd like to get one.
    Sent from my GT-I9505 using Tapatalk
    11-01-2013 08:31 PM
  3. King Mustard's Avatar
    <screeshot snipped>
    I have no Power Saving options enabled.
    Here is a link to the battery.
    11-01-2013 08:43 PM
  4. ladyhaly's Avatar
    Thanks for the link!
    The only other solution I can think of is to have an app that will override the system's screen brightness controller. Like Lux, for instance. Again, I am not sure if it will work, but they have a free Lite version so I guess it can be worth a try?
    11-01-2013 11:59 PM
  5. April Ballard's Avatar
    Has anyone found a solution to this infuriating problem? I just cannot for the life of me comprehend why Android would completely remove the ability to adjust MY brightness settings on MY phone regardless of what MY battery percentage is. Why would they care if my battery drains at lightning speed because my screen is 100% brightened?? And what's worse, the phone is practically useless when it does auto diim because it is ridiculously dark. What were they thinking??? It is crap just like this that caused me to switch to Android from Apple and all of their tight control over users and their devices. I tried downloading other apps that control brightness, but have had no luck.My phone is rooted.. Please, someone, tell me there is a fix for this frustrating and asinine problem that causes me to hate Android with a passion about once a day....
    591dave likes this.
    01-19-2014 02:33 PM
  6. 591dave's Avatar
    Exactly
    02-13-2014 08:51 PM
  7. BB_Berry's Avatar
    I was in the very same boat and I found this app in the Play Store that did the trick!
    RootDim [root]
    07-14-2014 03:52 PM
  8. Robert White1's Avatar
    Thank you!
    Actually there are more (Newer apps) that this provider wrote...
    just search for screendim at the playstore and the first item's first page gives three other apps that do the same thing. I just chose to DL the screendim (free) Root version and it does all that I want (so Far)
    Great post!
    Aloha!
    08-10-2015 03:54 PM
  9. ferika27's Avatar
    Sorry, for my Samsung g.T.4 LTE is not one of this apps working
    Greetings,
    Feri
    04-08-2016 06:01 AM
  10. vickgaminghd's Avatar
    Root your device and get yourself RootDim[root]. It totally works.
    04-10-2016 09:41 PM
  11. extraclass's Avatar
    It does that to give you a chance to finish what you are doing and turn the phone off or plug in a charger. Li batteries do not like to be discharged too far and the phone will cut it off before that happens. It is not good to run that battery completely dead!
    04-12-2016 08:02 PM
  1. What ever happened to the wood backs?
    By livetoride4666 in forum Moto X (2013)
    Last Post: 11-23-2015, 12:31 AM
  2. So I deleted the Operating System of my AT&T HTC One
    By Chris Cano in forum HTC One Rooting, ROMs & Hacks
    Last Post: 11-23-2015, 12:30 AM
  3. Let's see some Ultra home screens!
    By Westiemom in forum Motorola Droid Ultra
    Last Post: 10-29-2015, 06:22 AM
  4. Texting not working after switching from AT&T / iPhone
    By Davertron in forum T-Mobile LG G2
    Last Post: 11-13-2013, 04:12 PM
  5. Erratic Screen Color
    By Hydra Volt in forum Acer Iconia A200
    Last Post: 11-01-2013, 06:58 PM
