Results 1 to 2 of 2
    Default Some minor but annoying issues.... need a little help
    First off, using a T-Mobile Galaxy S4, rooted, but no custom ROM, Android 4.2.2, AMDL build version
    Defaults don't stick - asked often "which app to use" when opening or executing something. I tap the one I want, choose Always, and then get it later. Little issue, but frustrating.
    Automatic Brightness - not working. For example, in the car (not in a "car dock"), it will be super bright at 6pm. I have to go into settings, where Automatic Brightness is already checked, remove the check, then check it back, and then auto-brightness works fine. Seems to only be in the car. Again, not in a "dock mode" - just plugged in to a charger.
    Lock Screen - I used that Samsung TV app this weekend b/c my kids think it's totally cool (they're 8 & 11 - easy to impress!). Now, I get the TV controls up on the lock screen. I don't want them. How to get rid of them?
    Notification volumes - seem to default to zero sometimes - no idea why.
    Any thoughts?
  2. #2
    Default Re: Some minor but annoying issues.... need a little help
    Quote Originally Posted by o2bnclemson View Post
    Any thoughts?
    I have exactly the same problem on my Droid RAZR M. Looking for the answer to this.
  1. HELP!
    By Samuel Tregoning in forum T-Mobile Galaxy Note 2
    Last Post: 11-12-2013, 04:57 PM
  2. Urgent help needed
    By knikam in forum HTC Desire S
    Last Post: 11-12-2013, 03:47 AM
  3. notification bar issue
    By Patrick Bissonette in forum Sprint Galaxy Nexus
    Last Post: 11-12-2013, 01:26 AM
  4. Sprint Samsung Galaxy root help
    By Reapus in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-11-2013, 04:02 PM
  5. Software Update 4.3 Issue
    By Chris Dobo in forum Samsung Galaxy S4
    Last Post: 11-11-2013, 03:33 PM
