1. Brandon Haskell's Avatar
    I ordered a replacement screen with digitizer and front housing preinstalled for a S4 model SPH-L720 phone and received the correct model screen but the home/touch key flex cable that is pre-installed on the replacement screen is for a Galaxy S4 model GT-I9500. Because the flex cable is from a different model screen/phone it is not long enough to reach where it supposed to connect to. Is there any way to work around this without removing the screen from the housing? I ordered it with the housing already installed to avoid having to remove the screen but I don't see any way to fix the too short cable without doing that. Any advice? Or are my only options to remove the screen or return it to Etradesupply?
    11-12-2013 11:33 AM
  2. Brandon Haskell's Avatar
    11-13-2013 12:52 PM
  1. Sprint Galaxy Note 2 - Screen Auto Brightness
    By kanesmith41 in forum Sprint Galaxy Note 2
    Last Post: 11-15-2013, 01:11 PM
  2. Samsung galaxy s4 skype problems
    By Duncy14 in forum Samsung Galaxy S4
    Last Post: 11-13-2013, 07:12 AM
  3. S4 upgraded to android 4.3
    By Devilsbane in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-12-2013, 12:01 PM
  4. wssyncmldm AT&T software update??? Galaxy S4 Active Model I537
    By hpmini2009 in forum Samsung Galaxy S4 Active
    Last Post: 11-12-2013, 11:18 AM
  5. Samsung Galaxy S II - photo weird problem
    By fishbone5 in forum Samsung Galaxy S II
    Last Post: 11-12-2013, 09:48 AM
