Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By Randy Uecker
  • 1 Post By Victor Fronkenstein
    Shlomo Glazer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Galaxy S4 smartphone does not pair with my Plantronics PLT_BB903+ headset
    Hi,
    My new Galaxy S4 smartphone does not pair with my Plantronics PLT_BB903+ headset.
    Also, the headset does not pair with my wife's Smartphone Galaxy S3 mini.
    the Plantronics PLT_BB903+ headset, easily pairs with my old Blackberry 9780 bold.
    I am realy need the bluetooth link between my Galaxy smartphone and the Plantronics PLT_BB903+ headset.
    Please advise.
    Thank you in advance.
    Shlomo
  2. #2
    blademael's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have a plantronics backbeat go and I read on the sheet that came with it that i can't pair it with two different item, like if I want to pair it with another phone I have to unpair it before, but I dont know how to unpair it.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S4 smartphone does not pair with my Plantronics PLT_BB903+ headset
    Thank you for your prompt response. I tried but fail with the unpair way. In order to unpair, go to the "setting", switch on the "Bluetooth" and operate the "unpair" function. BR,
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi. found the way forward. Press the headset's "on" switch until pairing is completed. BR, Shlomo.
  5. #5
    scott jankowski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Follow this link Support Knowledge Base should help
  6. #6
    Randy Uecker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Re: Galaxy S4 smartphone does not pair with my Plantronics PLT_BB903+ headset
    Make sure the headset is off, then:
    Press the button you use to turn the device on ... press it & hold it down for 5-10 seconds and wait for a beep. This worked on my 520. I believe it cleared the pairing of my old phone and I was finally able to pair it with the new phone I just got.
    Make sure your phone is on and ready to pair (searching).
    Hope this helps. Good luck.
  7. #7
    DylanCornelius's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It worked! Thank you!
  8. #8
    Kenwyn Whitford's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    THANK YOU! Paired right up!
  9. #9
    Tristan Todd1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I concur.. 100% winning advice! Cheers man. ^^
  10. #10
    Victor Fronkenstein's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S4 smartphone does not pair with my Plantronics PLT Legend headset
    Here is a simple solution:
    1. Goto SYSTEM SETTINGS on the Note 4
    2. Under "Wireless and Networks" goto "Bluetooth"
    3. Press SCAN
    4. Hold the "CALL" button on your Legend while turning on the POWER BUTTON
    The Legend should start flashing alternately red and blue. Then the Note will see the Legend and you are off and running.
    Good Luck!
    Victor
    Neon50 likes this.
  11. #11
    nailsbyanni's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Victor Fronkenstein View Post
    3. Press SCAN
    Good Luck!
    Victor
    *****thanks so much for this post worked like a charm 😊
  12. #12
    Monica Semington's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just exchanged my recalled note 7 and I was using my Plantronics BackBeat Fit Bluetooth Headphones on it. I now have the new Note 7 and the bluetooth was not pairing. After following your directions it works now!!!!!
    Thank you!
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you!
  14. #14
    Neon50's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just a thank you for that solution. I have a ZTE Blade Q Lux (Telstra branded in Australia). Worked fine with my Plantronics M70 bluetooth headset before I upgraded the firmware. When I did neither, the headset or the phone even detected each other. I was so desperate I was considering a factory reset on the phone, which probably wouldn't have solved the problem anyway. Then I found the solution here i.e. holding down the large button on the side of the headset when I turned the power on, with the phone in scan mode at the same time. Thanks again.
  1. Battery case with built in SD slot for Nexus 5
    By Brian202020 in forum Google Nexus 5
    Last Post: 03-12-2014, 05:14 PM
  2. Charging My Nexus 7
    By gerryp123 in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-17-2013, 01:20 PM
  3. Replies: 2
    Last Post: 11-16-2013, 01:43 PM
  4. No Dialer Codes for Verizon Samsung Galaxy S4?
    By John Alden Meade in forum Verizon Samsung Galaxy S4
    Last Post: 11-14-2013, 04:17 PM
