Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 116
Like Tree15Likes
  1. #51
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Touchwiz wont stay as default launcher!
    I'm glad that worked for you. It hadn't worked for me when I tried it before (I thought it had, then it came back like 5-10 minutes later). Even if this solution works, you presumptively would have to do it every time you restart the phone.
    Again, I'll retry it with the latest build...
  2. #52
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Actually, I retried this and don't have the ability to force stop. That is ghosted out as an option. Do you have to be rooted to do that?
    Again, the only people that I've seen who have defeated this keeping the update are those who rooted their phone and deleted the TouchWiz easy altogether. My phone isn't rooted though and my prior rooting attempts failed.
  3. #53
    Hghlndr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey all! Happiest Holidays...
    Latest Google search update 3.1.8... 827 is golden. Works without TouchWiz screen showing up. Yes! Peace
  4. #54
    henrynks's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi iiari
    Not sure why you cannot 'force stop' TouchWiz easy home, though. And my phone is not rooted version, still intact and as original as it was since I got it
    This is how it looks like on my phone once I forced stop it. Strangely, it does not get into "Disabled" category on Application Manager. Perhaps compare your versions with what I have just to see if they are any different?
    TouchWiz easy home version 1.0
    TouchWiz Home version 4.3-I9505XXUEMJ5
    Google Search version 2.6.7.721924.arm
    My Google Search has been enabled and did a couple of reboots with no sign of problem re-occurring which make me a happy person! I intend to proceed with the update on Google Seach and see how it goes.
    Cheers!
    Quote Originally Posted by iiari View Post
    Attached Thumbnails Attached Thumbnails Galaxy S4: Touchwiz won't stay as default launcher!-screenshot_2013-12-12-15-30-36.png
  5. #55
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Hghlndr View Post
    I just updated that and it isn't working for me . Still asking me to select which TouchWiz version after every single home press out of Google search...
    Quote Originally Posted by henrynks View Post
    Hi iiari
    I don't know why either. I'll compare the versions and see if anything is different. Which carrier do you have? I have Sprint. I've sometimes been told that different carriers will enable or disable certain features, and this might be one of them. Are there any apps that anyone knows of that can force an app to stop?
  6. #56
    Patricia Bianco's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lokesh, thanks, this worked for me. I completely un-installed Google Search updates because I couldn't sort out how to choose just the last one. Anyway, I'm left with the original Google search. Then when I pressed the home button, it asked that annoying question one last time and has shut-up forever.
    Yay!
  7. #57
    henrynks's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm in Singapore, using SingTel as carrier. Not sure about this although I heard too different carriers offers different apps.
  8. #58
    STARGATE's Avatar
    Posts
    Global Posts
    9,260 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Hello.
    I'm also with Sprint and don't have that problem. Do you have the option to Force Stop the app as in my screenshot?
    If you do try to force stop it see if that works.
    Sent From Inside The TARDIS in a Galaxy S4 Away!
  9. #59
    STARGATE's Avatar
    Posts
    Global Posts
    9,260 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    After I posted the screenshot I've noticed another post from you that answers my question. 😕
    Ok, have you done a factory reset to see if that makes the Force Stop option available again?
  10. #60
    Fuego's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm on AT&T and have tried all of the above, and still have the annoying problem. I've done a soft reset/clearing ram and cache, forced stop on Touch Wiz Easy but the problem returns. I've been avoiding a full factory reset since reinstalling everything does not appeal to me. Had anyone on AT&T been able to resolve this completely for more than 2-3 days?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  11. #61
    Plow13's Avatar
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any luck?
    Sent from my SCH-I545 using AC Forums mobile app
  12. #62
    STARGATE's Avatar
    Posts
    Global Posts
    9,260 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    For those of you with Sprint, I woke up today to a new update.
    Hopefully it'll fix your problems.
  13. #63
    kbrady222's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Deleting the latest update to Google search solved the problem. Thanks for posting it
  14. #64
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by STARGATE View Post
    Hopefully it'll fix your problems. !
    Just downloaded it this morning and installed the Google Search update to find no change .
    Anyone make any progress with this? I'm wondering if I should ask Sprint to exchange my phone... Thanks!
  15. #65
    Plow13's Avatar
    Posts
    Global Posts
    96 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I pulled my battery out for a minute to do a complete power down after installing latest update and now it works for me. I'm on Verizon
  16. #66
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sadly, that approach didn't work for me either . And what impact should removing the battery have on anything?
  17. #67
    STARGATE's Avatar
    Posts
    Global Posts
    9,260 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    That sucks!
    My phone and the people I know that have a GS4 don't have that problem, so it's not widespread on all the phones.
    And that's why, I don't think Sprint will do anything, unfortunately.
    But you can try, you got nothing to loose!
  18. #68
    David Thomas13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just go to your apps and uninstall google search, that way you can can use other search engines to do your searches. It's google search updates thats causing the Touchwiz error. You don't need google search anyway. Use Firefox for searching.
  19. #69
    Amyswo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm on Verizon and the latest Samsung upgrade did the trick. Finally no more annoying message with Google search! Hope the upgrade helps others here.
  20. #70
    STARGATE's Avatar
    Posts
    Global Posts
    9,260 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    None
    Quote Originally Posted by Amyswo View Post
    I'm with Sprint and I didn't have this problem *Knocks on wood*
    But I know a couple of guys with Sprint that had this problem and the latest MK2 update fixed it and a WiFi problem too.
  21. #71
    Sylv1n's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lokesh Sastri View Post
    Guys, I MIGHT HAVE FOUND THE SOLUTION.
    Uninstall the latest search for Google Search (11/15/2013) - It is very unstable. When you hit the Google search bar and then the home button on some your Android devices, it will prompt you for the zillionth time "continue using action as..." where you'll have to select a launcher. I just uninstalled the latest update and it fixed it for me (at least for the time being). No more prompts - Touchwiz is stored as default launcher.
    Thanks Lokesh this fixed my issue of the annoying request to select which launcher you to use.
  22. #72
    gtjones7178's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I just recently updated Samsung hub and that is what started this whole mess with me. I uninstalled this update and now it works fine...hope this helps
  23. #73
    iiari's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't think I ever updated Samsung hub (it fact, it prompts me to update it) but forcing it to stop didn't change anything for me. This only reinforces my suspicion that some Samsung app is probably interfering with the Google Search update in some way and causing this. I've basically otherwise have given up and just biding my time with the "old" Google search until some point in the future when I update phones later this year or early next.
    Any other ideas are welcome!
  24. #74
    Triboman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It is does seem to be google search that is causing the problem. Switching of History seems to cure the problem too. Thanks for the tip, I have been putting up with this problem for months.
  25. #75
    Fernando Sortino Astolfi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It worked for me. Thanks a lot. It was driving me crazy. ..best regards
  1. Any way to disable Easy Launcher?
    By Sabban in forum T-Mobile Samsung Galaxy S4
    Last Post: 11-18-2013, 10:14 AM
  2. What launcher do you rock
    By TheJustPull in forum Verizon Galaxy S3
    Last Post: 11-18-2013, 03:27 AM
  3. Google Experience launcher
    By donsmith1964 in forum Verizon Droid DNA
    Last Post: 11-17-2013, 10:19 AM
  4. Default speaker?
    By Lynda-Lou in forum Droid RAZR
    Last Post: 11-15-2013, 12:03 PM
  5. Does anyone use the Next Launcher 3D?
    By dragoro in forum Samsung Galaxy Note 3
    Last Post: 11-14-2013, 01:38 PM
