12-07-2015 08:57 AM
116 123 ...
tools
  1. cmd280's Avatar
    Hey All ,
    Ever since 4.3, half the time when I click my home button the launcher select dialog box comes up where one is supposed to select their preferred launcher. Only problem is that I have no other third party launchers installed...only Touchwiz.
    Already tried factory resetting.
    Has anyone else run into this problem?
    Diana Tithof likes this.
    11-14-2013 09:06 PM
  2. blademael's Avatar
    I dont have this problem but I would install one free and when asked to select one select touch wiz and choose always
    Galaxy S4
    11-14-2013 09:27 PM
  3. francisco rodriguez5's Avatar
    I'm having the same problem... Just started today any fix??
    11-15-2013 02:06 AM
  4. estranho's Avatar
    I'm also having this same issue, I've tried several different launchers and it keeps asking me to pick one as the default launcher. I haven't yet updated to 4.3, but I did update the Google Search to 3.1.8.
    Fabio Marreco likes this.
    11-15-2013 08:31 AM
  5. davidleng7's Avatar
    I9500 4.3
    Facing this issue recently... It is very annoying. It pops up when I press the home button.. any fix?
    11-15-2013 11:30 AM
  6. Lokesh Sastri's Avatar
    Guys, I MIGHT HAVE FOUND THE SOLUTION.
    Uninstall the latest search for Google Search (11/15/2013) - It is very unstable. When you hit the Google search bar and then the home button on some your Android devices, it will prompt you for the zillionth time "continue using action as..." where you'll have to select a launcher. I just uninstalled the latest update and it fixed it for me (at least for the time being). No more prompts - Touchwiz is stored as default launcher.
    11-17-2013 02:59 AM
  7. Hghlndr's Avatar
    Haven't tried Lokesh's work around yet though am having the same situation on my VZ i545 S4.
    Posted and looked around found this bit: "if you go to settings, my device, then home screen mode select easy mode then click apply, THEN go back into settings, my device, home screen and change it back to standard mode it stops prompting you to choose when u press the home button."
    It did for a few hours....
    Finally cleared cache and data of Touchwiz under application management and it reset all the screens to factory; rebuilt all my Home and other screens to find the offending request still occurs. Silly glitch....
    11-17-2013 11:49 AM
  8. RickzSII's Avatar
    I had this same issue with 4.2 A simple hard format fixed the issue
    Haven't had this issue with 4.3 yet crossing fingers since its so Damn annoying
    11-17-2013 08:41 PM
  9. sec1rxg's Avatar
    This absolutely fixed my issue with default launchers, thanks
    11-17-2013 09:17 PM
  10. STARGATE's Avatar
    Which solution?
    The one from Hghlndr or the one from Lokesh Sastri?
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    11-17-2013 09:39 PM
  11. francisco rodriguez5's Avatar
    Lokesh solution fixed mine :-)
    11-17-2013 10:35 PM
  12. STARGATE's Avatar
    Orale! :thumbup:
    11-17-2013 10:45 PM
  13. davidleng7's Avatar
    Lokesh's solution fixes this! Thanks!!
    STARGATE likes this.
    11-18-2013 03:16 AM
  14. cmd280's Avatar
    So I discovered that once I uninstalled the subway ordering app the problem stopped.
    11-18-2013 08:57 PM
  15. STARGATE's Avatar
    Lol! Your phone didn't want you to get food from subway. 😉
    11-19-2013 06:39 AM
  16. Hghlndr's Avatar
    Just an update if any still experiencing this awkward glitch... no need to factory reset nor clear data from Touchwiz app, simply follow Lokesh's suggestion.
    Thanks everybody for all your comments and assistance; indeed I have realized Googles Search latest update (3.xx) is the culprit! (THANK YOU LOKESH)
    Downgraded to last update, (2.xx) and everything is back to normal with TouchWiz.
    Sad to loose Google latest efforts though!
    11-19-2013 03:41 PM
  17. storelli's Avatar
    Perfect solution...Thanks, it was driving me crazy.
    11-20-2013 02:40 PM
  18. David Thomas13's Avatar
    I removed the Google Search update and select reset to factory settings for Google Search and my TouchWiz prompts stopped. YES!!! Victory!!!!
    11-21-2013 02:16 PM
  19. David Thomas13's Avatar
    Your suggestion worked for me. Thanks!!!
    11-21-2013 02:18 PM
  20. David Thomas13's Avatar
    Uninstall Google Search updates and your problem will go away. I'm trying to figure out how to prevent updates to Google Search.
    11-21-2013 08:07 PM
  21. mattyloveau's Avatar
    @Lokesh Sastri - I need to seriously thank you for this - I did a factory reset on my phone and still had this same issue. If you look around the web, there are countless people having a similar issue. Someone needs to contact Google to let them know their own search engine is crippling the experience in their OS. Thanks again !
    11-22-2013 06:05 AM
  22. Kingp78's Avatar
    Thanks So much! That pop up was driving me nuts lol. now only have to figure out why my group text freeze
    11-25-2013 05:58 PM
  23. Tracey Geracia's Avatar
    11-25-2013 10:11 PM
  24. iiari's Avatar
    11-25-2013 11:04 PM
  25. iiari's Avatar
    This is the only place on the Web I read a fix that worked. Thanks! I called my carrier to let them know how to help others. Hope Google knows this!
    11-25-2013 11:05 PM
116 123 ...
  1. Any way to disable Easy Launcher?
    By Sabban in forum T-Mobile Samsung Galaxy S4
    Last Post: 11-18-2013, 09:14 AM
  2. What launcher do you rock
    By TheJustPull in forum Verizon Galaxy S III
    Last Post: 11-18-2013, 02:27 AM
  3. Google Experience launcher
    By donsmith1964 in forum Verizon Droid DNA
    Last Post: 11-17-2013, 09:19 AM
  4. Default speaker?
    By Lynda-Lou in forum Droid RAZR
    Last Post: 11-15-2013, 11:03 AM
  5. Does anyone use the Next Launcher 3D?
    By dragoro in forum Samsung Galaxy Note 3
    Last Post: 11-14-2013, 12:38 PM
