Plow13
Active member
Re: Touchwiz wont stay as default launcher!
Any luck?
Sent from my SCH-I545 using AC Forums mobile app
Any luck?
For those of you with Sprint, I woke up today to a new update.
Hopefully it'll fix your problems. !
Just downloaded it this morning and installed the Google Search update to find no change .
Anyone make any progress with this? I'm wondering if I should ask Sprint to exchange my phone... Thanks!
I'm on Verizon and the latest Samsung upgrade did the trick. Finally no more annoying message with Google search! Hope the upgrade helps others here.
Guys, I MIGHT HAVE FOUND THE SOLUTION.
Uninstall the latest search for Google Search (11/15/2013) - It is very unstable. When you hit the Google search bar and then the home button on some your Android devices, it will prompt you for the zillionth time "continue using action as..." where you'll have to select a launcher. I just uninstalled the latest update and it fixed it for me (at least for the time being). No more prompts - Touchwiz is stored as default launcher.
Finally found a solution! "Forced stop and Disabled TouchWiz Easy Home killed the problem permanently!" Yippie!
For those that having similar annoying problem as mine, please try this. I have also re-enabled Google Search ver 2.xx (have not try to update to the latest yet) and the problem has not resurfaced.
PS: My problem may differ from others that has successfully resolved by removing Google Search updates and revert back the version to 2.xx. My issue was more of both TouchWiz Home and TouchWiz easy Home cannot co-existed (and running). One had to be disabled i.e. TouchWiz easy Home
Refer/See my previous posting with screen shots dated 11-28-2013, 09:31 AM.
Cheers!
