Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Like Tree3Likes
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S4: Android OS Battery Drain
    I charged my Galaxy S4 last night up to 100%. Exactly 10 hours and 5 minutes later my battery is at 40%.
    If you can't see the picture, here's the apps that drain my batery:
    Android OS - 72%
    gpsd - 16% (I have GPS turned off, so I don't know what this is here)
    Screen - 4%
    As you can see, Screen being at 4%, I haven't used my phone at all, because I've been sleeping during the entire 10 hours ( I charged my phone and went to sleep). Basically, Android OS is draining almost all the battery by itself (72%, it's not even funny.
    Can anybody help me?
    D Max1 likes this.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,076 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Android OS Battery Drain
    Quote Originally Posted by dickharper View Post
    http://img824.imageshack.us/img824/3669/p2ez.png
    Android OS - 72%
    Screen - 4%
    When the device is idle like that, it is going to normally show Android as draining your device.
    - - - Updated - - -
    By the way, Welcome to the forums.
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, I understand that. What I don't get is why the battery has come down to 40% without even using my phone. My aunt has a Galaxy S4 and she uses her phone often, and she showed me her phone was at 59% after 13 hours since last charge. Mine is at 40% without even using it, that just doesn't make sense. The battery doesn't even last a whole day, no matter whether I use my phone or not.
  4. #4
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    Yeah, but 6% battery loss per hour while idle, with over 4% per hour of it being from "Android OS," seems excessive. I see much closer to 2% battery drain per hour and I have lots of stuff turned on.
    The OP will have to download some better battery debugging apps (I use GSam Battery Monitor and Wakelock Detector) to figure out what's really going on. A quick reboot might be worth it as well.
    MJW1 likes this.
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, I was thinking of doing a Factory Data Reset. The thing is I don't wanna have to download everything all over again but I just might have to do that. I'm gonna try that next and charge my phone and post again all the percentages and show you guys so you can tell me whether you think there's an improvement or if you think there's still a problem.
    If it asks me to update the OS, should I?
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    By the way, thanks. I will download those apps and see if they can help. But first I'm gonna do a factory reset and see if things improve at all.
  7. #7
    Almeuit's Avatar
    Posts
    Global Posts
    23,246 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Is your aunt in edge like you for data? Edge is slow and anything using it.. Even a little sync.... Will drain it much more than let's say a stronger signal like 3g.
    Sent from my T-Mobile Note 3 using AC Forums.
  8. Thread Author  Thread Author    #8
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, we're both using 3G.
    Update: I did the Factory Data Restart. Re-downloaded some of the apps I had, not all of them. Declined to update some apps that I never use. Had to update Google Services though, because otherwise I can't use YouTube app. It's almost done charging, I will update when I finish testing the battery duration and will post another picture.
    I appreciate your responses and your help. Thank you.
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK so I tested it again. This time after 9 hours 50 minutes my battery is at 49% instead of the previous 40%. The percentages are about the same really, so I'm not gonna post a picture. It's not that big of an improvement as I expected but I guess it's something. I suppose I'll just have to live with it, and get a backup battery.
  10. #10
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have to agree with Almeuit on this one, why is it showing E for Edge if you are on 3G? Do you have Wifi at home? Try either staying on WIFI or turn off your mobile data and see what results you get
    STSVA likes this.
  11. #11
    Modeling2014's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Listen. The problem is from an application installed in your phone. Like mine. I have installed Vine. My battery at 98%. After 5 hours I found my phone turned off. If your phone is rooted try to install an application that changes the apps permission. Like what I did.
  12. #12
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Modeling2014 View Post
    I don't agree, if that was the case it would be showing the APP itself under Battery with a percentage it's sucked. Not just Android OS.
  13. #13
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mhinc View Post
    You'd think so, but that's not always the case. I had Battery Guru go rogue once and drain my battery in a few hours and it showed up as "Android OS" in the Android battery reporting. GSam gave much different results and let me know what app caused the problems. IMO, the battery usage stats in Android are terrible.
  14. #14
    Bachir El Charif's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I updated to 4.3 this morning, my battery was 94% after the update, now and after 5 hours my phone beeped the 5% battery low indication. i have a S4 and the android os consumed 61% of my battery (screen 6%), this is very stupid and annoying, i am looking now to downgrade to 4.2.2
  15. #15
    WhiteiPadMini's Avatar
    Posts
    Global Posts
    374 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Bachir El Charif View Post
    I suggest you try doing a soft reset first. First you power off your device, then simply hold the power button + home button + Volume up at the same time, Once you hear the vibrate let go of the power button but continue to hold the home button + volume up until you see the Logo and on the top right corner, it's small but is in Blue, you should be in recovery mode. Use the volume button to navigate and the power button to enter. You should fine the one that says something like delete/clear system cache?
    If that doesn't work then do a factor reset. This helped me on my battery life and has been great.
  16. #16
    Kvant_hv's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is a bug in google backup service, google backup service acquires wfii connectivity lock and does not release it for hours which prevents device entering deep sleep and as a result drains battery. Fortunately you can disable backup in Settings->Accounts->Backup and Reset-> uncheck 'Backup my data'. This should resolve the issue ... after a full recharge monitor your battery stats - Android OS should NOT be on the top.
    Sorry, disabling backup didn't help - encountered the same problem. There is indeed a bug that some OS module that holds a wlan lock but it's not a backup service. I suspect that full charge triggers this flow. Device restart will temporarily fix the issue. I'll post if i will find the causer, sorry for mislead.
    After some investigation I've came to a conclusion that the problem is in the wifi manager itself. In normal case this lock should be held no more that 1-2 seconds for the entire battery charge. I've developed an application that will give an automated solution for this problem. http://kvant.store.aptoide.com/app/m...r%20(OS%204.3)
  17. #17
    mmse88's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am on Sony Xperia Z Ultra 4.3. Had a factory reset but still no luck.
  18. #18
    r3nzodj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just hit rock bottom today.. after how many days of battery draining from 'Android OS' and 'GOOGLE PLAY SERVICES'... Now im 6 hours in charging and all I got was 93%.. thats 6 hours!!! Android OS still sucks battery more than the screen. I just dont get it. I hope they fix this soon. Im very happy with the battery life of my Note 3 before this happened. Now it wont even last a whole day with minimal use.
  19. #19
    MJW1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Best thing I ever dowloaded.It solved most of the problems with my battery usage on my Experia Z up to now.Just need to delve deeper to see what else I can Stop or DeInstall.Many Thanks for the information..
  20. #20
    Demi9OD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Since this is the #1 hit on Google for Android OS Battery Drain, thought I'd share the solution I found elsewhere. Very simple, just disable Auto Backup (of photos) in Google+.
    After sitting in my pocket with basically no use for 8 hours now my phone battery is at 93% instead of 65%, and Android OS is second in battery use to "Phone Idle" instead of being first by a large margin.
  21. Thread Author  Thread Author    #21
    dickharper's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Demi9OD View Post
    I'm gonna give this a try. After all these days trying a bunch of different things, rooting my phone, using wakelock detector, deleting apps that ran on the background, still Android OS is the one that is on top draining the battery. My battery one day lasted 1d 12h without charging! That proved to me that the battery has the ability to last a very long time, it's just that some apps drain way too much battery too fast.
    Lately, with 4.3, my battery life lasts around 12 hours (very little difference between very little use and a lot of use, even idle)
  22. #22
    Brunga's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the app, I will soon give it a shot.
    I have had this problem for some time on a Samsung S4 (I am aware of it since I have Cyanogenmod 10.2, probably it was present also with stock OS since battery times are not very different).
    In my case, (manually) switching wifi on/off does not seem to improve the situation, as the wakelock remains in place; only reboot works, and the issue reappears after about 3 hours. Is your application doing anything else besides switching Wifi on/off? Or is it doing it in a different way than through the interface?
    One curious note is that I do not have this problem when I visit my family abroad, even if I have wifi on all the time. It seems somehow that this issue has external causes. I tried deactivating the 5 GHz to replicate the conditions at my family's place, band but the issue reappeared anyway.
  23. #23
    shlomoreuven's Avatar
    Posts
    Global Posts
    42 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    im in this problem...
    what to do?
  24. #24
    r3nzodj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im also having the same problem.. please help. Has anyone solved this? Thanks
  25. #25
    ithink2020's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was having issues as well and narrowed it down to two things. I was seeing AndroidOS using about 47% of the battery and Google Play Services taking about 23%.
    1. AndroidOS Fix: Go to Google Settings...Google+. Under general settings go into Auto Backup (of images to Google+) TURN THIS OFF!!! Even though I hardly every take pics, it was still sucking the life out of my battery. After turning this off and recharging, AndroidOS is now using about 7% battery.
    2. Google Play Services Fix: Go to Settings...Locations Services. TURN OFF "Use Wireless Networks". I use to have that off, but a recent update must have turn GPS off and turned that on. After turning that off and turning GPS back on Google Play Services is only using 2% battery.
    I couldn't get through an 8 hour work day the past couple weeks. I now have GPS & Bluetooth (with a fitbit connected) enabled and my battery is lasting over 24 hours!
    Hope this helps!!!
    Matt
    ivoda likes this.
  1. Replies: 4
    Last Post: 11-21-2013, 02:41 PM
  2. Quantum Rush - Android Gameplay
    By cheaterandroid in forum Android Games
    Last Post: 11-19-2013, 11:34 AM
  3. [FREE] SunGazing Android App
    By Emanuela Kireva in forum Android Apps
    Last Post: 11-19-2013, 10:40 AM
  4. Android Junk Files Cleaner
    By bcsoft in forum Android Apps
    Last Post: 11-19-2013, 08:20 AM
  5. Synching Tasks between Android, Outlook and iPad
    By Eoin MacManus in forum General Help and How To
    Last Post: 11-19-2013, 07:47 AM
