1. dougltc's Avatar
    Thinking of getting this for my 2013 Nexus 7:
    https://play.google.com/store/device...reless_charger
    Will it work with my S4 (Sprint)?
    Sent from my Nexus 7 using AC Forums mobile app
    11-28-2013 07:50 AM
  2. nelschroeder's Avatar
    I would say yes. I charge my N7 with my Samsung GNex charger all the time. All the non apple devices use the same micro USB connectors. I use generic cables and wall chargers all the time between as all my devices with no problem.
    11-28-2013 09:58 AM
  3. draconianchaos's Avatar
    I think the OP is referring to wireless charging.
    Is the s4 completely stock? I know there is some sort of aftermarket wireless charging option for the s4 but I don't think it has qi charging built in.
    11-28-2013 10:46 AM
  4. dougltc's Avatar
    Yes ... stock. I thought that the S4 had wireless charging built-in ...
    Sent from my SPH-L720 using AC Forums mobile app
    11-28-2013 11:45 AM
  5. Kilgore Trout's Avatar
    I have three Qi chargers, one that I got from Verizon, a Nokia, and a generic one that I got last week on dailysteals. All work fine with my nexus 7 2013 and my s4. As long as it all uses the Qi standard, you can mix and match as well.
    For various reasons, I would recommend the Nokia above all others.
    11-28-2013 12:15 PM
  6. Kilgore Trout's Avatar
    The s4 does have inductive charging built in, but you have to put the inductive battery cover on it.
    The cover is $19, with the Samsung coupon.
    Phones with removable batteries usually require a different battery door for Qi charging.
    11-28-2013 12:17 PM
  7. draconianchaos's Avatar
    Not to my knowledge. shopandroid I believe sells the proper accessory but you could probably find it cheaper from somewhere else.
    11-28-2013 12:17 PM
  8. dougltc's Avatar
    I found this budget charging pad and card for the phone recommended on a different forum:
    http://www.amazon.com/dp/B00DRB2ENK?...cUvbUpU3279192
    Going to give it a try...
    11-28-2013 12:32 PM
  1. Wireless charging not working after 4.4 KitKat update.
    By pixportadev in forum Google Nexus 4
    Last Post: 07-17-2014, 12:17 PM
  2. Problems after the unsuccessful attempt of download of a Google Play App
    By Andrea Lixi in forum Samsung Galaxy S3 Mini
    Last Post: 11-30-2013, 12:03 AM
  3. Replies: 1
    Last Post: 11-29-2013, 12:36 AM
  4. Google Books on Nexus 7
    By Gazella in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-28-2013, 10:45 AM
  5. galaxy s4 not receiving emails
    By rodger reinders in forum Samsung Galaxy S4
    Last Post: 11-28-2013, 09:48 AM
