Results 1 to 12 of 12
    WillRunForBeer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Any way to do more advanced wifi settings on GS4? [4.3]
    I have a very specific problem, but I think my question has general interest.
    I noticed that I can't connect to my Nikon WU-1a (camera hot spot). First it says, "Checking the quality of your internet connection, then I get the error "Network disabled because internet connection is slow". For this function there is no need to connect to the internet as the Nikon application just needs to interact with the camera. The connection from phone to camera works fine with my wife's Galaxy S3 [4.1.2], and I *think* it worked ok on my S4 before I had the 4.3 update, but am not sure.
    I suspect a change was made to the wifi application in 4.3 to actually check internet connectivity, e.g., to see if some URL is accessible. Since my "internet" is my camera, this isn't possible.
    http://forums.androidcentral.com/sam...onnecting.html seems to indicate that there is a way to get into a view of more settings than "wifi->advanced" on the Galaxy S3.
    This method didn't seem to work (or at least I couldn't figure out how to do it) on the Galaxy S4. Is there any way to get into more detailed settings on the S4?
    My carrier is Verizon, in case that that matters.
  2. #2
    Paulyester's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Any way to do more advanced wifi settings on GS4? [4.3]
    +1 on this, I can no longer connect to GoPro Hero3 Black after 4.3. Zero problems before update.
    Sent from my SCH-I545 using Tapatalk
  3. #3
    troshs's Avatar
    Posts
    Global Posts
    981 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Definitely an issue. I went to my exes house and tried to log on to his wifi (which my phone had no problem connecting when I lived there and it was also okay before the update...) does the same thing. Also at home my wifi randomly disconnects. Its driving me bat s***!
    EDIT: I got into the debugging screen on my S4. Hit the menu key and selected Wifi. The button to turn off power save mode was there....now I just sit back and wait to see if I have any more disconnects.
  4. #4
    Paulyester's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay guys I figured it out. Go to your wifi page where you would select a connection. Then click your menu button, the soft button with a couple lines (very bottom left on S4). Then select Advanced. In the Advanced settings page, uncheck the Auto Network Switch. Connected right up to the GoPro.
  5. #5
    Paulyester's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's a screen shot of the Advanced screen
    Attached Thumbnails Attached Thumbnails Any way to do more advanced wifi settings on GS4? [4.3]-uploadfromtaptalk1385920398116.jpg
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks, Paul -- that seems to work for my device as well, although I get "wireless network is unstable" message
    Glad it does because I'm looking at getting a gopro as well
    I wonder what the side effects are, for normal use?
    I have a support message outstanding to samsung -- if they have another solution, I'll share it here as well
  7. #7
    JP Wheatman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My problem is that once I am connected to my GoPro, the wifi signal gets dropped after like a minute or so. I didnt have this issue before the update. Any help would be sweet!
  8. #8
    Bradfordj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same issue with my Sprint S3, 4.3 update and a GoPro 3 Black. I have been working with GoPro and they just sent me a replacement camera which has the same issue. You might want to contact them and give your experience. (FYI I have tried all the above and more, just can't stay connected for more then a few minutes).
  9. #9
    Bradfordj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    GoPro got back to me. I have a solution for at least for my situation. In addition to all of the stuff above, I needed to turn the Sprint Connections Optimizer off. After that my GoPro stayed connect and if I lost the connection it was the first to be tried coming back. See
    Turn Sprint Connections Optimizer on or off - Samsung Galaxy S® III 32GB
  10. #10
    StevenCinNYC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for posting this. I couldn't figure out where to find the Advance WiFi settings. Simple enough when you know where to look, but I didn't know until I read your post. So Thank You!
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paulyester View Post
  12. #12
    GadgieCAT13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Any way to do more advanced wifi settings on GS4? [4.3]
    THANK YOU! I was at my wits' end with this thing!
  1. Google services are not working with WiFi
    By Alan De Maman in forum Android 4.4 KitKat
    Last Post: 06-30-2014, 06:23 PM
  2. AT&T Galaxy Note 2 - 4G Lte and Wifi on at the same time (Note 2)
    By Danchele08 in forum AT&T Galaxy Note 2
    Last Post: 12-24-2013, 05:10 PM
  3. Cyanogenmod on Galaxy S4? System apps?
    By Bruninho98 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-04-2013, 08:31 PM
  4. Moto X - Can't Sign in to Google
    By TechTinker in forum Moto X (2013)
    Last Post: 11-30-2013, 05:39 AM
  5. Phone not turning on :(
    By noone22 in forum Samsung Galaxy S3 I9300
    Last Post: 11-30-2013, 03:58 AM
