Results 1 to 3 of 3
    adam.bean's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default Help resetting Galaxy S4 to stock
    Hey all,
    While attempting to fix the 4.3 issues, at some point I attempted a root to load a custom firmware. I don't believe I ever succeeded as a super user check regurarly fails. I am switching out to a new phone with my carrier and I'm worried that they'll charge me for the phone. When I start up the phone now, it shows Samsung with an unlocked icon and under it showing "Custom". This makes me worry that per their rules and regulations, they'll say I altered the phone.
    How at this point do I get it 100% back to stock? I did a master reset; however it didn't change the boot splash screen.
    Thanks!
  2. Thread Author  Thread Author    #2
    adam.bean's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default Re: Help resetting Galaxy S4 to stock
    Just did some searching and appears others have reported this as well ... and they are stock. I never loaded a custom firmware or anything. I only attempted to gain super access and it failed so I removed everything from then. So is there any way to get rid of this to avoid possible issues when I return it? I don't know if I did this or if it was like this when I got it (it's a refurb from the carrier).
    adam.bean's Avatar
    Posts
    Global Posts
    41 Global Posts
    I tried following this, and this is what I was doing before that failed (motochopper). After running run.bat the install goes and then just says "failure" in the command prompt (). So I'm not sure what to do here; however could really use some help.
    Thanks
  1. Replies: 21
    Last Post: 03-27-2014, 08:46 AM
  2. Verizon Note 3: how to disable power saving mode?
    By wmscottmc in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-14-2014, 02:31 PM
  3. Galaxy S Blaze Booting to Odin Mode After Attempted Firmware Upgrade
    By simpmg in forum T-Mobile Galaxy S Blaze 4G
    Last Post: 12-10-2013, 07:42 PM
  4. Widgets and Apps disappear randomly on my gS4! Please Help!
    By camcam9406 in forum Sprint Samsung Galaxy S4
    Last Post: 12-09-2013, 01:22 AM
  5. Replies: 2
    Last Post: 12-08-2013, 11:37 AM
B
