Turn your phone into a real universal remote! IR Universal Remote uses your phone's built in IR Blaster to control infrared devices such as TV, Cable Box, Radio, DVR, DSLR Remote , Blu-Ray, CD, Audio and much more. All you need is a Samsung phone or tablet with a built in IR Blaster. This application has thousands of supported manufacturer models and is continuously growing in size of supported devices. This is the most universal application on Google Play. Whether your kids have lost the TV remote or you just want to turn up the game at the bar you can do it with IR Universal Remote.
NEW! 12/14/2013: Drag and Drop! Drag and drop buttons for saved remotes. Re-arrange all of your saved remote buttons by dragging and dropping. Long tap a button to see position options. You can also fine tune after dragging and dropping by selecting fine tune.
LIRC Database now available! Thousands of new supported devices have already been added. Send me your custom LIRC files if you want me to add them to the Online LIRC database. This application is constantly growing in supported devices.
Android 4.4 Kit-Kat is supported!
CyanogenMod is Supported. CM11 confirmed!
FREE FEATURES:
*Limited GUI remotes that can't be edited or saved with a banner ad at the bottom.
*Access to over 300000+ Online IR Database codes (limited to viewing as lists).
UNLOCKED (PRO) FEATURES:
*Online IR Database available as GUI (now with quick save option).
*Manually input IR codes not found in the IR database.
*Create and Save Custom Remotes from the IR database for use offline.
*Custom Themes (Change Layouts / Backgrounds)
*Hide/show buttons.
*Drag and drop buttons
*Change button text and color, size, and position.
*Quickly edit saved remote buttons (Long tap button).
*Widgets. -widgets are linked to last used Saved Remote.
*Tablet and Phone layouts supported.
FREE FEATURES:
*Hide/show buttons.
