Results 1 to 12 of 12
    Default IR Universal Remote - Turn your S4 into a real universal remote.
    Turn your phone into a real universal remote! IR Universal Remote uses your phone's built in IR Blaster to control infrared devices such as TV, Cable Box, Radio, DVR, DSLR Remote , Blu-Ray, CD, Audio and much more. All you need is a Samsung phone or tablet with a built in IR Blaster. This application has thousands of supported manufacturer models and is continuously growing in size of supported devices. This is the most universal application on Google Play. Whether your kids have lost the TV remote or you just want to turn up the game at the bar you can do it with IR Universal Remote.
    NEW! 12/14/2013: Drag and Drop! Drag and drop buttons for saved remotes. Re-arrange all of your saved remote buttons by dragging and dropping. Long tap a button to see position options. You can also fine tune after dragging and dropping by selecting fine tune.
    LIRC Database now available! Thousands of new supported devices have already been added. Send me your custom LIRC files if you want me to add them to the Online LIRC database. This application is constantly growing in supported devices.
    Android 4.4 Kit-Kat is supported!
    CyanogenMod is Supported. CM11 confirmed!
    FREE FEATURES:
    *Limited GUI remotes that can't be edited or saved with a banner ad at the bottom.
    *Access to over 300000+ Online IR Database codes (limited to viewing as lists).
    UNLOCKED (PRO) FEATURES:
    *Online IR Database available as GUI (now with quick save option).
    *Manually input IR codes not found in the IR database.
    *Create and Save Custom Remotes from the IR database for use offline.
    *Custom Themes (Change Layouts / Backgrounds)
    *Hide/show buttons.
    *Drag and drop buttons
    *Change button text and color, size, and position.
    *Quickly edit saved remote buttons (Long tap button).
    *Widgets. -widgets are linked to last used Saved Remote.
    *Tablet and Phone layouts supported.
  2. #2
    Default Re: IR Universal Remote - Turn your S4 into a real universal remote.
    Nice, keep up the good work. I have way too many remotes now a days. Time to add another one.
    Samsung Galaxy Note 3 using Tapatalk
    Check out the new updates!
  4. #4
    Love your avatar! Go Hawks!
    - - - Updated - - -
    Quote Originally Posted by Eclipse2K View Post
    Oops, forgot to quote ya....
    Love the Avatar!
    Thanks for the support guys
    New updates
  7. #7
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    620 Global Posts
    ROM
    Stock
    Looked interesting and went to play and searched but never found it.
    Sent from my Nexus 7 using Tapatalk 4
  8. Thread Author  Thread Author    #8
    @Cigar-Junkie
    This application is only available for devices with IR Blasters (Mainly the Samsung Galaxy line of devices). Some additional devices will be available when they are upgraded to KitKat. These would be devices such as the LG G2 and HTC One. These devices running KITKAT will be supported.
  9. #9
    Why would this be better than free Watch On?
    Sincerely,
    An amazing S4
    Galaxy S4
    XOOM
    Tab 2
    rootless
  10. #10
    Posts
    Global Posts
    620 Global Posts
    ROM
    Stock
    I have the S4 but it is possible I searched with my tablet
  11. Thread Author  Thread Author    #11
    @droidntn
    Great Question! This application allows you to set different backgrounds and has buttons that can be dragged anywhere on the screen and re-sized dynamically. This application also has many different supported device IR codes than Watch On. You can also set one remote layout to control multiple devices such as your TV, Cable Box, Audio all without switching any layouts. There are widgets too. The application is free to download and all of the buttons are available for free. Upgrading will allow access to extra features that are not found in Watch On such as dragging and dropping buttons.
  12. Thread Author  Thread Author    #12
    ttt
  1. Real Snow Live Wallpaper
    By Daniar in forum Android Applications
    Last Post: 01-11-2014, 10:19 AM
  2. AT&T Samsung Galaxy S4 - Texting Questions
    By tem#AC in forum AT&T Samsung Galaxy S4
    Last Post: 12-19-2013, 09:31 AM
  3. WTB: WTB: Samsung OEM S4 charger (home)
    By delta7 in forum The Marketplace - Buy, Sell & Trade
    Last Post: 12-18-2013, 08:18 AM
  4. How do you reset my S4 without losing my contacts?
    By Charlene1991 in forum Samsung Galaxy S4
    Last Post: 12-16-2013, 02:30 PM
  5. Replies: 0
    Last Post: 12-16-2013, 12:57 PM
B
