Results 1 to 7 of 7
    Default Power Save Mode
    Anyone know exactly what does Power Save Mode does? And I don't mean the obvious like saving battery. I can't find any details on what exactly happens by selecting Power Save. Thanks.
  2. #2
    Default Re: Power Save Mode
    Check this thread out.
    What does the Android 'power saving mode' actually do?
    You should be able to select the Power Saving Mode by clicking on the words rather than the On/Off toggle. This brings up options.
    Samsung Galaxy Note 3 using Tapatalk
  3. #3
    UJ95x's Avatar
    Posts
    Global Posts
    5,581 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    If you mean power saving mode on the GS4 specifically, it's supposed to lower screen brightness, limit the processing power, eliminate haptic feedback
    I don't see much of a difference between having it on or off so I just leave it off
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
  4. #4
    Tap the option, turn it on, and you'll see what the settings are. You can enable or disable the 4 available options independently. There's also a tutorial page you can read.
    PLEASE, when asking for help provide as much information as possible. We can't help unless we know what the symptoms are and what you did before they began.
    If I've helped you, please click the "Thanks" button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    Quote Originally Posted by meyerweb View Post
    Sorry forgive me but I see a toggle that's all. On and off no options. What am I missing here?
  6. #6
    UJ95x's Avatar
    Posts
    Global Posts
    5,581 Global Posts
    ROM
    Quote Originally Posted by THEPRFCT10 View Post
    I think what he meant was to turn it on
  7. #7
    Quote Originally Posted by UJ95x View Post
    Yep, thanks.
  1. Saved files getting deleted.
    By sonicresidue in forum Google Nexus 4
    Last Post: 02-11-2014, 08:01 PM
  2. Make Android device with NO SAFE MODE
    By Mohammed Taheer in forum Introductions
    Last Post: 12-18-2013, 03:31 PM
  3. Replies: 2
    Last Post: 12-17-2013, 05:40 PM
  4. Replies: 0
    Last Post: 12-17-2013, 04:17 PM
  5. How to Prevent auto save image attachments from Yahoo Mail etc.
    By moemaya in forum Sprint Samsung Galaxy Note 3
    Last Post: 12-17-2013, 04:02 PM
B
