Hey guys i tried to factory reset my samsung galaxy s wifi 5.0/player 5.0 by holding up volume and power on and then volume on than it came MANUAL MODE it says:
Android system recovery <3e>
Enter: OK Key Select : Vol UP / Vol DOWN
reboot system now
apply update from sdcard
wipe data/factory reset
wipe cache partition
______________________________________
--Copying media files...
Successfuly copied media files.
# MANUAL MODE #
--Appling Multi-CSC...
Successfully applied multi-CSC.
And i want to factory reset but i can't press OK button because my homebutton doesnt work and i can't do anything i try to power off and every time i power it on again this MANUAL MODE comes
If you know can you plese tell my what to do?
