Results 1 to 9 of 9
    Default Is there an easy way to silent the phone
    Hi just wondering if there is an easy way to silent the phone.
    IPhone use to have the switch which I really miss.
    If the s4 us locked ypu have to unlock it then turn down can't the volume buttons work when phone is locked ?
  2. #2
    Default
    Quote Originally Posted by Mark Rider2 View Post
    They do I think
    Edit: they don't appear to. You need music playing
  3. #3
    Default Re: Is there an easy way to silent the phone
    hold the power button
    Thanked by:
  4. #4
    STARGATE's Avatar
    Posts
    Global Posts
    4,101 Global Posts
    ROM
    None
    I know what you're talking about, I missed that from my Palm Prē!
    Apple, in true Apple fashion copied that from Palm!
    Anyway, on the GS4 press the home button or the power button once, then press the power button again for a second or two and you get this👇
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    If I'm very clever, and I'm more than clever, I'm brilliant! I might just save the World, or rip it apart!
  5. #5
    If you have certain situations or times when you want your phone silenced, on vibrate or with full sound, you can use apps like Llama or Tasker to automate it. I have my phone go silent at work or if it's charging at night and on full volume otherwise. That takes care of >90% of the situations where I have to change my phone volume.
    Thanked by:
  6. #6
    STARGATE's Avatar
    Posts
    Global Posts
    4,101 Global Posts
    ROM
    None
    Quote Originally Posted by garublador View Post
    Yup, that's a good idea too. 👍
    Thanked by:
    Cheers chaps still not as good as the switch. There are some things that are so handy on the iPhone the silent switch is the main one. Can do it with out taking it out your pocket but will use your suggestion
    So thanks
  8. #8
    So thanks
    Isn't that basically the same as pressing the power button a tad? (Post #2)
    Sent from my Nexus 5 using Tapatalk 2
  9. #9
    STARGATE's Avatar
    Posts
    Global Posts
    4,101 Global Posts
    ROM
    None
    Yea, just press the power button till you get the options on my screenshot above!
    Thanked by:
  1. When will Nexus 5 come to Verizon?
    By Eric Mccuaig in forum Google Nexus 5
    Last Post: 01-24-2014, 10:20 AM
  2. Replies: 21
    Last Post: 01-14-2014, 08:16 AM
  3. Galaxy S3 is very, very slow
    By Omar Moatamed in forum Samsung Galaxy S3 I9300
    Last Post: 12-31-2013, 07:57 AM
  4. Galaxy S3 - Pls help can sync Andriod to pc
    By blue3k in forum Samsung Galaxy 3
    Last Post: 12-25-2013, 01:52 AM
B
