Results 1 to 6 of 6
    delta7's Avatar
    Posts
    Global Posts
    552 Global Posts
    Default Any advice for setting up the s4?
    Coming from a iPhone with Universal Search just by swiping down I need help setting up my s4. I need to organize it a little bit.
    Any programs you recommend? I want a music page, business page and so forth. Also a better way to search for programs.
    Sent from my SPH-L720 using Tapatalk
  2. #2
    Default Re: Any advice for setting up the s4?
    I would download Google Keyboard as I don't find the stock one to my liking.
  3. #3
    Quote Originally Posted by delta7 View Post
    By the way, universal search exists on the S4, just use that Google search bar on your main home screen
  4. #4
    What I do is I categorize similar apps I use the most together. I have my gallery and camera combined. I have a folder with my most common apps in it. Reddit, Facebook, etc. That way all my common apps are right there at my fingertips. Apps I don't use as often I just grab from the app drawer.
    I do recommend downloading Google keyboard as someone else has recommended. Also download Nova launcher. It has much more flexibility over touchwiz.
  5. #5
    Google keyboard and Nova are a great starting point.
    I also recommend Swiftkey keyboard... It reads your mind.
    Posted from my SGH-I337M
    delta7's Avatar
    Posts
    Global Posts
    552 Global Posts
    I have SwiftKey I'll try Nova
  1. rooting this s4
    By Troy the Creator in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-05-2014, 10:12 PM
  2. how do you get cwm recovery for e4gt running gb27?
    By goozing in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 01-05-2014, 01:36 PM
  3. Google hangout or the normal text stock app
    By thetechteen420 in forum Samsung Galaxy S4
    Last Post: 12-26-2013, 01:54 PM
  4. Replies: 10
    Last Post: 12-24-2013, 08:17 PM
  5. Looking for App that suggests similar songs
    By Nemesis-X in forum Android Applications
    Last Post: 12-24-2013, 08:13 PM
B
