Results 1 to 7 of 7
    Default Where is my newly folder created using build - in desktop in Android.
    Hi I am new to this forum.
    My conundrum is, I can't find my newly created folder when I use a file manager to search for it, where is it in the "Physical" so to say spot.
    I am technical but new to Android.
    In other words where is my folder that I've created on one of the screens by using left menu touch-button and choosed create and then folder and well there, typed my foldername and there it was.
    Any Ideas?
  2. #2
    Default Re: Where is my newly folder created using build - in desktop in Android.
    Welcome to Android Central! Are you talking about a folder you created on a homescreen, or a folder you created in the file directory? A folder on the homescreen will not correspond to a folder in the file directory.
  3. #3
    Quote Originally Posted by Danyom View Post
    Any Ideas?
    It should appear on the screen you created it in. I created a folder"testing folder" on the near empty 3 rd screen of my S4, dragged my app shortcut for "Telkom" onto it. Telkom is now accessible from within the newly created folder
    It is a screen folder only. If you want to create an system folder you will have to do it in "my Files" using the tree to select the location
    Spikes
    GT-5100 4.1.2 Jelly Bean
    I-9500 4.3 Jelly Bean
    Aha, So any folder created on any homescreen "Lives And Work" only in the graphical interface.
    No wonder I couldn't find the folder using search with the file-manager.
    Can I in some way "convert" a homescreen folder to be accessible in the filesystem?
    It would be easier for my mother to use homescreen folders.
    Regards
    David
    hi and thanks
    I am talking about a homescreen folder
    Regards
    David
  6. #6
    Easy to do using ES file explorer. Select the folder from your system folders, tap and hold to select a tick will appear in the rhand bottom corner of the folder. Select "more" from the ES file explorer menu then select add to desktop and OK. That shortcut folder will point to the directory and open thd the contents.
    Thanked by:
    STSVA
    That's it, Exellent
    Thanks
    Best Regards
    David
  1. Straight Talk using Verizon
    By frugalmomy in forum Other US Carriers
    Last Post: 02-18-2014, 01:11 PM
  2. Need help finding an email app to do custom reply like desktop app.
    By shaselai in forum General Help and How To
    Last Post: 12-28-2013, 09:27 PM
  3. Kies doesn't read my phone?
    By thegeekwithnolife in forum Samsung Galaxy S3
    Last Post: 12-27-2013, 08:49 PM
  4. [Free] My Deco Memo Sticker: Making memo for your mobile phone
    By inexco in forum Android Applications
    Last Post: 12-26-2013, 10:48 AM
  5. android 4.3 for laptop? instead of windows??? any advice?
    By elvinsrudy in forum General Help and How To
    Last Post: 12-25-2013, 10:10 PM
B
