Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By cosimomedici
  • 1 Post By Eclipse2K
    Question Dumbest help question ever
    Please don't hate me for asking this, but I have an issue with my phone that I can't figure out for the life of me.
    Every morning, around 7AM (but not always exactly at 7), my phone makes a very loud noise - two tones, descending, and it's not any of the stock notification noises on the phone. It's not a message alert, calendar event, or anything else I can identify, and it doesn't come with any message on screen.
    Does anybody know what this is, and how I can turn it off? Or am I going completely insane?
    EDIT - phone is a Verizon Galaxy S4, model # SCH-I545, kernel version 3.4.0.
  2. #2
    Default Re: Dumbest help question ever
    Quote Originally Posted by cosimomedici View Post
    Odd...my step-father complains of the almost exact same thing, only his is at 0900 (this is US Eastern time, what time zone are you in?). He claims that his is the "default" message sound on his device, though I've never been around to hear it go off myself, and he's not exactly very tech-literate either, so I can't verify that. Either way, he says it happens every day, and when he checks his phone, there is no new notification or message of any kind. I looked his phone over, and couldn't find anything that may be triggering such as an alarm or calendar event, etc.
    Sorry I'm not more help, but I'm mainly posting here to subscribe to the thread and see if anyone else has any insight....
    Pete, thanks a million for the response - yeah my phone is default EST.
    I used to think that I was pretty tech-literate, but this is making me question that assumption.....
  4. #4
    Have a look at the health app sensor settings. Some setting there may be triggering the notification
    GT-5100 4.1.2 Jelly Bean
    I-9500 4.3 Jelly Bean
  5. #5
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    Quote Originally Posted by Bosbouer View Post
    This👆
    Also, OP, do you have it on the charger overnight?
    I've noticed with my GS4 that I have a setting to notify me when it's charged. That sound is like the one you mentioned.
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    If I'm very clever, and I'm more than clever, I'm brilliant! I might just save the World, or rip it apart!
  6. #6
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    Oh, btw, welcome to the forums cosimomedici!
    There is no such thing as a dumb question!
    Remember that!
    Thanked by:
    Stargate and Bosbouer, thanks a million. S health had been disabled but I re-enabled it and turned off notifications before disabling it again. The phone was off the charger this morning, so thinking it's not that. Will report whether it happens again tomorrow having made the change in s health...
    STARGATE likes this.
  8. #8
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    No problem. Let us know what happens.
  9. #9
    Let us know. I don't think that fixed it though if you had it disabled because that disabled notifications too. It's not running at all but I've seen stranger things.
    Samsung Galaxy Note 3 (Verizon)
  10. Thread Author  Thread Author    #10
    So it happened again... I think it's happening at 0705 and 1705 exactly, and only on weekdays. Maybe something calendar related?
  11. #11
    Have you checked the default alarm appto see if some hidden alarm is on?
    I find your lack of faith in android disturbing.
  12. #12
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    That's a little weird, and yes, check the calendar to be on the safe side.
    Have you done a factory reset?
  13. Thread Author  Thread Author    #13
    Yup, calendar and alarm both checked. Did a reset and it's still happening. So strange....
  14. #14
    Default
    I know that you have nuked it from orbit, but here is my suggestion: go into each app installed on your phone's info and see which ones can use notifications and prevent your phone from sleeping. Go through ALL of them, just to be sure. If not, then just turn the volume completely off i guess.
  15. #15
    Also, remember there are no dumb questions, just dumb answers. Good life advice!
  16. #16
    After you did the reset, did you reinstall all your apps at once? I know it'd be a pain, but another reset and then just restoring one app at a time and waiting to see which one makes the sound happen would be one way to nail it down. Either that, or darth android's suggestion of going through app by app to see which ones have the capability to do this. Or is there an app that can scan installed apps for specific permissions?
  17. #17
    Quote Originally Posted by Dave-in-Decatur View Post
    App permission manager can. I think.
  18. #18
    tgp
    tgp is offline
    tgp's Avatar
    Posts
    Global Posts
    1,765 Global Posts
    Quote Originally Posted by STARGATE View Post
    You've obviously never worked in retail! ;-)
    Sent from my Nexus 5 using Tapatalk
    I have a Nexus 4, an iPhone 5, and a Lumia 520, and I like them all. Is something wrong with me? (I really should edit my signature sometime. I have only 1 of these 3 phones anymore, and even that one is mostly unused because it's been superseded by its big brother!)
  19. #19
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    Quote Originally Posted by tgp View Post
    You're right! 😜
  20. #20
    The answers many employees give are usually dumber than the question asked.
    tgp likes this.
  21. #21
    STARGATE's Avatar
    Posts
    Global Posts
    4,070 Global Posts
    ROM
    None
    Quote Originally Posted by Eclipse2K View Post
    Yea, unfortunately that's the true!
  1. Please help with new tablet!
    By Sebastian Kaine in forum Misc. Tablet Chat
    Last Post: 01-25-2014, 10:43 PM
  2. Help - HTC One in boot loop
    By SJGoel in forum HTC One Rooting, ROMs & Hacks
    Last Post: 12-27-2013, 01:03 AM
  3. HTC Incredible All Types of Recovery Fail! Please Help
    By Randy Goode in forum Verizon Droid Incredible
    Last Post: 12-26-2013, 04:12 AM
  4. who ever used en.ofweek.com ?
    By Harpersarah in forum General News & Discussion
    Last Post: 12-26-2013, 01:43 AM
  5. Please Help - confused Kindle user!!!!
    By Kay Dennett in forum Amazon Kindle Fire HD
    Last Post: 12-26-2013, 12:57 AM
B
