Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By B. Diddy
    Default Several Galaxy S4 Problems
    Every since the 4.3 update my phone keeps freezing, the battery drains pretty quick even if the screen is locked, runs very slow and other minor issues. Is there anyway I can fix this? This is the first android phone ive had so not to sure how everything works yet. I have to admit this is the worst phone ive ever had but unfortunately stuck with it for another year and a half. Aslong as I can get it back to working as it should it will do
  2. #2
    Default Re: Several Galaxy S4 Problems
    Welcome to Android Central! Unfortunately, there seems to be a lot of posts about problems with the 4.3 update. If you haven't already done so, try doing a system cache partition wipe, which can sometimes make things run a little more smoothly. You won't lose any personal data or settings. Follow the instructions here under "Wipe Cache Partition":
    done it and its not fixed anything. cheers anyway was worth a try
  4. #4
    You could consider downgrading back to 4.2.2. Check out this thread starting at post #11 by Golfdriver97, our Senior Ambassador: HELP PLEASE!!! Samsung Galaxy S4; 4.3 Update turned off WiFi for good?
    Golfdriver97 likes this.
    im on Samsung updates website just now. there is loads of different files for my phone. the thing that's thrown me off is the region code. how do I find out what it is for uk? also all the files are 4.3 theres no version lower. I did hear there was a 4.3 fix released but I cant seem to get my phone to find it. will the fix be on this website?
  6. #6
    I'll ask Golfdriver97 to help out--wait a few ticks ...
    thanks
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,823 Global Posts
    ROM
    Stock Moto X
    Quote Originally Posted by Stuart Campbell View Post
    thanks
    You can get the region code by connecting to Kies. It will give your baseband version and the region code in Parentheses.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
    Thanked by:
  1. Replies: 6
    Last Post: 02-14-2014, 07:36 PM
  2. Nexus 5 VS Galaxy S3 LTE (T-Mobile)
    By nikon5400 in forum Google Nexus 5
    Last Post: 01-21-2014, 11:37 AM
  3. help with mail problems on my samsung galaxy note 3
    By hoffer1 in forum Samsung Galaxy Note 3
    Last Post: 01-17-2014, 08:33 AM
  4. Active Notifications Problem
    By SandmanATHF in forum Moto X
    Last Post: 01-02-2014, 10:16 PM
  5. Unauthorized App notification whenever wi-fi is turned on Galaxy S4. Help!
    By ledzep1594 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-02-2014, 09:38 AM
B
