Results 1 to 3 of 3
    Default Ridiculous Battery Drain from Google Services
    So this is for my dad's AT&T S4 which he uses very rarely but needs it to last for the whole day. Its worked great but in the last week the battery is draining like crazy. I will post screenshots which speak for themselves. Also no apps were ever open or running during this time.
  2. Thread Author  Thread Author    #2
    Default Re: Ridiculous Battery Drain from Google Services
    Ridiculous Battery Drain from Google Services-screenshot_2014-01-02-16-34-39.jpg
    Ridiculous Battery Drain from Google Services-screenshot_2014-01-02-16-34-34.jpg
    Ridiculous Battery Drain from Google Services-screenshot_2014-01-02-16-34-43.jpg
    Ridiculous Battery Drain from Google Services-screenshot_2014-01-02-16-34-49.jpg
  3. #3
    Google Services gets out of control sometimes. A couple of suggestions - open the Google Settings app and disable Google apps from being able to access the phone's location at any time. I'd also suggest checking Google+ sync settings. Also, is he using Google Now? It's reported to be a battery hog. You might also look into the Snapdragon Battery Guru app, which helps control app syncing behavior. Finally, does he need to have wifi on 24/7, as indicated by your screenshots?
    Samsung Galaxy S4 (Verizon - SCH-I545) - Android 4.3
  1. Replies: 35
    Last Post: 01-13-2014, 09:10 PM
  2. Replies: 6
    Last Post: 01-03-2014, 12:10 PM
  3. Nexus 4 on AOKP- No wireless service shows R symbol
    By jinjin12 in forum Google Nexus 4
    Last Post: 01-03-2014, 10:13 AM
  4. Replies: 1
    Last Post: 01-02-2014, 10:05 PM
  5. What do I expect from micro-SD card
    By jamak in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-02-2014, 05:39 PM
B
