Results 1 to 4 of 4
    Default S4 battery life of 7 hours, charging time for 4-5 hours - !heat!
    Hey
    I just bought my S4 and i must say im not very happy.
    It heats up, even in my pocket when I havent done ANYTHING with it. Battery drains by 23% (in standby!!!) within an hour on bad days and it takes forever to charge.
    Also the camera seems ****ty (compared to my old S3, which broke) and pixelated.
    Could it be a hardware fault, does anybody else have similar feelings about the phone?
    If i just got a bad one (e.g. processor "broken") I think I will exchange it for a new one. If all of you got just used to those problems, I will go for nexus 5 or something.
    Thanks for your help
    P.S.: how can I customize the bottom row of apps (thats on every page) - i cant seem to just drag my favourite apps there.
  2. #2
    Default Re: S4 battery life of 7 hours, charging time for 4-5 hours - !heat!
    Battery shouldn't discharge that fast. It should also charge quicker. I would probably take it back to get replaced.
    You can change the dock icons in Nova launcher.
    Sent from my LG-G2 using Tapatalk
  3. #3
    UJ95x's Avatar
    Posts
    Global Posts
    5,580 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Sounds like a defective phone. I'd call it in for a replacement
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
  4. #4
    At the least it sounds like a defective battery, and maybe a defective phone. On my Verizon S4 I can just drag/drop icons to or from the docked app row at the bottom of the screen. There appears to be a limit of 5 icons there, so if you already have that many you may need to drag one out before you can add one. It's difficult to assess whether you have a problem with the camera without seeing a sample shot showing the problem.
    Samsung Galaxy S4 (Verizon - SCH-I545) - Android 4.3
  1. Replies: 4
    Last Post: 02-28-2014, 05:26 PM
  2. Tylt Vu overheats battery
    By chrispher86 in forum Nexus 5 Accessories
    Last Post: 02-15-2014, 11:16 AM
  3. Galaxy S3 I9300 - "Contacts" not working at all for weeks
    By dyuk in forum Samsung Galaxy S3 I9300
    Last Post: 01-09-2014, 09:15 AM
  4. Clockworkmod on S4 4.3?
    By drooskiii in forum Samsung Galaxy S4
    Last Post: 01-04-2014, 11:17 PM
B
