Results 1 to 7 of 7
    Matthew Halton's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Volume Control
    Hi, I'll listen to music on my GS4 and during one song, the volume will be somewhat low- so I turn it up. Then when the next song plays- IT BLASTS MY EARS!
    Does anyone know of an app that will go into my audio files and optimize the volume levels for each song?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Volume Control
    Is the song in the same format/media as the rest? Sounds like song might have been recorded at a lower Sound volume and it's playing lower than the rest as you are experiencing. I don't think there is a way to fix that other than to obtain another version of the song.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They all are the same format. I do use an app called "Music Maniac". Would that be the cause? This is the only place I receive my music.
  4. #4
    tmozer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some where along the line in setting up the sound on my S4, I was asked if I wanted to normalize the volume of the sound files and I turned that feature on. All my MP3's now play at the same volume from the phone.....
  5. #5
    Faloogs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was having the same issue but now I use the power amp application, paid version and it allows you in the settings to play all the songs at the same volume.
    Posted via Android Central App on my awesome Samsung Galaxy s4
    Matthew Halton likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tem#AC View Post
    Was it "Adapt Sound"?
  7. #7
    tmozer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Matthew Halton View Post
    Yes, if memory serves me, it was Adapt Sound.
  1. Changing volume stops playback on S3?
    By Keld Jeppesen in forum Samsung Galaxy S3
    Last Post: 06-14-2014, 01:20 PM
  2. Sprint Galaxy S3 - Call volume very low after 4.3 update
    By gossamer#AC in forum Sprint Galaxy S3
    Last Post: 05-17-2014, 09:49 AM
  3. Galaxy S4 - Ringtone is way too low even on max volume.
    By DasPhillipBrau in forum Samsung Galaxy S4
    Last Post: 01-16-2014, 11:06 AM
  4. Volume suddenly goes to zero, then have to restart phone
    By vamsikatta in forum Nexus 4 Accessories
    Last Post: 01-03-2014, 11:25 AM
  5. Receiver crackle/vibration in call half-max volume
    By canucks4life in forum Google Nexus 5
    Last Post: 01-02-2014, 05:15 PM
